Newbie HD / Mac Pro INSTALL HARDWARE question
Hey Guys - I'd appreciate some help if possible
I have a new Mac Pro and an HD2 Accel I have the Core installed in Slot 2 and the Accell installed above it in Slot 3. The little flex cable is going from the Core's Port A to the Accel's Port B Everything is running and seems to be working FINE but ONLY if I hook the digilink up to the Accel card. If I hook it up to the Core Card, when I launch PT I get : "Unable to find an Audio Interface attached the the first HD card. Please check your power and digilink cables " I ran a digitest and it sees both cards - although the Accel card fails a loop test - everything else passes Any insight ?? |
Re: Newbie HD / Mac Pro INSTALL HARDWARE question
You've got your flex cable hooked up backwards. It goes from Port B of the core card to Port A of the accel card.
Thank you very much , Shawn. I'll change it around
Newbie: How to install ProSessions? | Chrisss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2007 07:14 AM |
Can't install pro tools... Newbie question! | phxepccrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-23-2007 12:36 PM |
Newbie question: hardware or software synths? | #6 | Virtual Instruments | 5 | 07-30-2006 09:01 PM |
newbie question about re-install to PTLE 6.7 | aero69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-04-2006 11:00 AM |
Newbie Question about Hardware Inserts | ssd | Tips & Tricks | 11 | 11-22-2002 09:42 PM |
