Old 11-06-2006, 07:37 PM
David Schmelick David Schmelick is offline
Default MBox2 Pro:Zero-Latency Hardware Direct Monitoring?
I've owned an original MBox since its release, and I'm planning on upgrading to the MBox 2 Pro. My question is this: is there latency-free direct hardware monitoring with the MBox 2 Pro, as there is with the original MBox? In other words, If I mute the track I'm recording to and just listen to the audio signal as it passes through the interface, is there still zero-latency? I know that the MBox and MBox 2 have a 'Mix' knob, and that the MBox 2 Pro does not.
Also, with my original MBox, I got used to the tracking latency issue, where every recorded take had to be Shifted 164 samples earlier. Is there a similar latency issue here as well, or has it been taken care of?
Thanks in advance!
mbox 3 & latency-direct monitoring and punching in? coolbro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-17-2011 09:57 AM
Direct Latency Free Monitoring on an MBOX Pro 2 solidsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-11-2008 01:43 AM
no low latency monitoring w/mbox2 pro? jcg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-25-2007 09:40 PM
Mbox2 Pro: Zero Latency Monitoring Path? jeff markham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-25-2006 09:15 AM
Mbox2 low latency monitoring dtrusz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-15-2006 10:26 AM
