Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 10-29-2020, 02:54 PM
Roger Stauss Roger Stauss is offline
Default Pro Tools 2020.9.1 not seeing iLok License
Just installed 2020.9.1 When I launch ProTools I'm being asked to select a license to activate. The "next" button is grey. ProTools does not see the perpetual code on my I lok. An Avid window pop up shows the locations where the licenses reside and I fsee them in my account.
Am I missing something?
Thanks for the help.
Last edited by jeffro; 10-29-2020 at 03:00 PM. Reason: Moved from other thread - unrelated.
Old 10-29-2020, 03:13 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: PT cannot find my perpetual license
Looks like 1 of your 2 licenses should support 2020.9.1 but the Release Limit date isn't correct. I'll start a support case for you to get more info and get this solved.
linkedin
Old 10-29-2020, 04:15 PM
Thank you Jeff. I'll be back at the studio at 9am ET.
Old 11-07-2020, 03:39 PM
405voiceguy 405voiceguy is offline
Default Re: Pro Tools 2020.9.1 not seeing iLok License
I'm having the exact same problem. Pro Tools doesn't see my iLok and won't authorize to launch the program.
Old 11-07-2020, 05:24 PM
jeffro's Avatar
Welcome to the community. Will get a support case going if I don't find one for you...
linkedin
Old 11-08-2020, 03:27 AM
Ben Jenssen's Avatar
It happened to me yesterday; PT had been running for 24 hours or more, being used on and off, now in the background. Then the little notification popup top right on the screen that usually says: Ilok Cloud authorization confirmed, or something to that effect, now said: Can't authorize, something, something. It goes away before I can really read it.
It's the second time in a few weeks.
I open PT, it says I must insert Ilok or reconnect to ilok Cloud or PT will quit in 5 min. I open Ilok License Manager and can't see my PT license. Looks like everything else is there. I log in, log out, fiddle around (while PT quits) and somehow I get to "Restore Ilok Cloud Session" (I'm not shure what that means exactly) and my license shows up again, active, I can relaunch PT, and I'm back to normal.
I have a very stable and fast internet connection, and was streaming stuff while this happened, so I'm pretty shure it wasn't a bad connection on my side.
I'm sorry, I see now that this is perhaps not very relevant to this thread, as my issue is with Ilok Cloud and OP is not. Could be though.
Old 11-08-2020, 09:35 AM
jeffro's Avatar
Originally Posted by Ben Jenssen View Post
...the little notification popup top right on the screen that usually says: Ilok Cloud authorization confirmed, or something to that effect, now said: Can't authorize, something, something. It goes away before I can really read it...
I don't think it's related (can move to a new thread if needed).
https://status.ilok.com doesn't show any recent issues. Did you Close Your Cloud Session then Open Your Cloud Session during your troubleshooting?
linkedin
Old 11-08-2020, 09:51 AM
Do what you think is best.
I posted because I thought it might contribute, as it had to do with license disappearing. But then I saw that OP had nothing to do w/iLok Cloud. I don't know.
Thanks.
I really don't know what that means; a cloud session. I assume it has nothing to do with a PT session.
When I got iLok Cloud 6 months ago, I just activated my licenses and started using the software. I never started or closed any cloud session as far as I know. I'm guessing it has to do with being able to quickly change all licenses to work on a different machine?
Added: When this happened to me, PT had been running idle with a small session open for many hours, and I was using a browser and doing simple things. It came out of nowhere, just like the last time.
Pro Tools 2020.3 does not see my ilok license Bhang Pro Tools 2020 12 11-19-2020 06:47 AM
Pro Tools 2019 perpetual license to 2020 avasound Pro Tools 2020 7 07-05-2020 08:31 PM
FS: Pro Tools Ultimate 2020 Perpetual License RedEyeJedi Buy & Sell 6 06-18-2020 07:45 AM
Pro Tools 2020 no license received jacksband Licensing & Accounts 2 05-05-2020 09:25 PM
Pro Tools Perpetual License with 1-Year Updates and Support (until 12/2020) smokeynyc Buy & Sell 8 02-23-2020 04:02 PM
