Old 10-22-2020, 09:45 AM
EGS's Avatar
EGS EGS is offline
Default fix distortion in audio restoration project?
Hey all,
I've got an audio restoration gig, consisting of cleaning up several precious old out-of-print classical records. One in particular has brief moments of distortion at loud peaks. It is clean except for these peaks. This is not digital clipping, but rather an analog distortion present on the source. We've even been able to examined more than one (identical) LP pressings, and the distortion is present in the same spots on all.
How to fix?
My best solution - so far - is to use Izotope RX to manually select and lower the gain of the tiny bits of distortion, often working the frequencies in-between the music when possible. Sometimes this kinda sorta works...
Help!
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.5 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 10-22-2020, 09:52 AM
Default Re: fix distortion in audio restoration project?
That would have been my suggestion too. Maybe check their website and look for some tutorial videos on that function? Then there are some other plugins that are worth a demo:
https://accusonus.com/products/audio...era-de-clipper
http://www.perfectdeclipper.com/
Old 10-22-2020, 12:40 PM
EGS's Avatar
EGS EGS is offline
Thnx I'll check those out
Click for demo
Old 10-22-2020, 02:28 PM
daeron80 daeron80 is offline
First, congrats! That's a cool gig.
Second, if the distortion was electronic, that's a tough problem, especially if it was transistor breakup. Almost intractable in some cases. Zoom in to the detailed waveform level and see where the discontinuities lie. If they're restricted to the high amplitude portion of the waveform, that's easier to deal with. If they lie along the ramp up or down, several dB below the peaks, then digging out between the overtones may be the best strategy.
If it was mechanical distortion during pressing, which is more similar to clipping, that can sometimes be moderated with the De-clip module of RX. Zoom in and adjust the threshold until it's catching most of the discontinuities. You'll lose some high end detail, but it can be an overall improvement.
Don't forget to try Interpolate and the various Spectral Repair modes. Sometimes they'll surprise you.
David J. Finnamore
Nyquist was right.
PT 2020.11.0 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Old 10-23-2020, 05:55 AM
musicman691 musicman691 is online now
I've done vinyl restoration on and off for over a decade using various tools and RX is pure genius with the modules it has. Well worth the money & time spent with it. Is the distortion in one or both channels? If only one channel try bringing audio from the non-distorted channel (if the vinyl is stereo).
Something to think about is it might just be an instrument or instruments played a bit too forcefully and they just got blatty. Or a mic just got overdriven (thinking ribbon mic here).
Old 10-23-2020, 10:52 AM
itsjustmeee123 itsjustmeee123 is offline
Question... how does RX do with clipped vocals? I have a project where the singer is recording remotely from her home and sometimes the vocal files she sends me are squared off at the top and there’s various degrees of distortion in the louder parts.
Old 10-23-2020, 01:52 PM
RX De-clip module pretty hit or miss for me. Sometimes I am amazed with the results, and sometimes no matter what I do it only sounds the same or worse. It really depends on the source material, and it definitely requires a lot of trial and error with adjusting settings and re-rendering (from the raw audio). Anything that is severely distorted will never sound pristine, but De-Clip can improve things, sometimes significantly, many times marginally.
Scott Gatteño
Yessian
Old 10-23-2020, 02:12 PM
The secret with a lot of rescue work in RX is to do things a little at a time; don't try and fix it in one pass.
Old 10-23-2020, 04:03 PM
seanmccoy seanmccoy is offline
My experience exactly. It's occasionally jaw-dropping, usually an improvement, and a total fail only once in a while. Clearly it depends on the nature and severity of the distortion. But overall I've definitely had more successes than disappointments.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2020.11, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2019.10
Old 10-26-2020, 08:35 AM
Bingo.
David J. Finnamore
Nyquist was right.
HELP! M-Audio Project Mix+Intel Quad6600+PTMP7.3=Distortion! RICKSTER7 Pro Tools M-Powered (Win) 17 10-07-2019 10:09 PM
Restoration of bad audio Postman Post - Surround - Video 11 06-24-2015 01:19 PM
Audio restoration plug-in garimpo Post - Surround - Video 5 06-14-2008 07:20 PM
Audio restoration.... assemblyworker Tips & Tricks 5 06-19-2007 10:21 AM
restoration project woes trexonbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-17-2006 02:04 PM
