Enable Phantom Power on 96 i/o and 7.4HD
I have an analog 96 i/o interface with a Mac G5 OSx, and I can't seem to use my condenser microphone successfully.
I'm used to locating a +48v switch on my old Digi002 rack, but I don't see one on the 96 i/o. Do I enable phantom power in my 7.4HD software somewhere, or do I need additional hardware? I'm not using a mixer, but plugging my cable straight into the TRS input in the back. |
Re: Enable Phantom Power on 96 i/o and 7.4HD
the 96 is only a AD/DA converter
you need some mic pres to bring the mics up to line level and supply phantom power if they needed
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
What hardware is considered standard for this purpose? Something affordable, but excellent none-the-less.
I have a scarlett 8i6 focusrite, but that's just another interface (although it has good preamps). |
u could use a mixing board but a pre amp would be much better
Focusrite OctoPre Mk II Dynamic would be a good choice. Presonus D8 will also work at a lower price(but I like the OctoPre Dynamic better). If the 96IO has an ADAT lightpipe input, then either of those preamps could connect with lightpipe, and bypass the 96 IO's cheap converters(same as 003).
If you still have the 002 rack....Maybe you could use it.....I have one of the new Mbox Pro modules that I use with pretty good results....It's firewired into another mac but the seperate audio outs go into the 96i inputs....So I'm using the Mbox for the phantom power/XLR input and a trs output....You could do something similiar I imagine with your 002....moon
002R Faults + power harness + no phantom power | DaveSB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2009 01:10 AM |
recording with phantom power *and* without phantom power simultaneously | SweetSoulSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-22-2008 07:40 PM |
002 No Phantom Power | muzishiper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2008 07:27 PM |
Phantom power and mic with power supply? | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2005 12:56 PM |
>> do i need phantom power? << | megahurt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2004 03:09 PM |
