Best way to breakdown tracks to separate sessions?
Hi, I recently tracked about 8 songs with my band and I recorded all of the songs one after another in the same session. Could someone give me advice on the easiest way to break each song up into their own sessions?
Digi002 7.4 Mac G4 10.4 |
Re: Best way to breakdown tracks to separate sessions?
"Save as"
Zoom way out, look for waveform gaps in between songs, slice & dice 7 times using command-E. You can undo if you accidentally slice a quiet part of a song. Then rename each new region so you can import to new sessions for each one.
Or 'save as' 8 times using different names, then each new session could be trimmed down to the one song. This way makes the timeline about 7 times longer than you need, although you can trim that down too.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
Is there a way to separate tracks from an existing mix? | mark007 | General Discussion | 9 | 06-21-2011 12:15 PM |
How to merge several separate PT sessions into one ? | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 03-04-2011 05:56 PM |
separate songs on long sessions? | hendymail | Tips & Tricks | 5 | 01-19-2005 12:03 AM |
Making separate tracks for each key | mentalmusic | MIDI | 5 | 11-04-2002 03:02 PM |
How to separate tracks | fredbeg | Digidesign Hardware & Software | 3 | 07-23-2001 03:32 AM |
