Old 12-06-2013, 03:13 PM
Raoul23 Raoul23 is offline
Default Gain Staging??
It's come to my attention for quite a while now that I'm not to good at gain staging
I've put this in the getting started section coz all the posts might help others as well as me
When I track I have the metering set to pre fader. I always try my hardest to have the level just touching the yellow on the loudest parts (-6) and have the input monitoring selected (as I'm on HD) so I can monitor the signal coming in. When I add a plugin say for example waves CLA 2A the input level increases on the fader meter. I then check the input on the plugin is just hitting -6 which is the same as the signal coming in when the plug is inactive. If this is correct and the fader meter shows an increase in signal I turn down the output on the CLA 2A making the fader level meter the same for both when the plugin is active and inactive.
Now if I add another plugin I want the input to be -6 on the plugin meter and weather the plugin is active or inactive the fader meter should still be hitting -6 as well, have I got this right???
Hope I've made sense and I'm doing things right if not please advise and shed some light on what I can do to improve this
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 12-06-2013, 03:33 PM
Meads Meads is offline
Default Re: Gain Staging??
I'm fairly new to mixing music, so maybe I'm doing it all wrong, but I'm not that delicate about hitting a specific peak.
I try to keep track levels within reason, and make sure plugins are hit with healthy levels on their input. But I'm not going all scientific about it. IMHO you hurt the creative process of mixing by being that accurate, and I do not see any benefits to it.
I'll happily stand corrected by the more experienced music-mixers, though.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 12-06-2013, 03:40 PM
That's the thing when in pre fader metering I have to be kind of specific like this so I don't end up overloading and clipping my sub mixes without knowing. I would say they always hit exactly -6 but I always try to be around that area :)
Raoul Crane
Old 12-06-2013, 03:46 PM
Bookerv12 Bookerv12 is offline
Hey there,
I don't want to make it seem like it isn't important, but don't be to scientific with the gain staging.
What does help is...
Consider the yellow meter in PT red. (Yellow is the new red)
There was a time when we had to have pretty healthy levels hitting tape decks and such to push the noise floor down and saturate the signal, but that time is over.
Even at a pretty low level, your tracks are pretty high resolution.
It's a good habit to get into in a daw to keep the levels a little more sane.
There is no benefit to hitting things hard. (For the most part)
Turn your monitor volume up.
If you see any of your plugins hit red, rethink your levels.
One of the first things I do when I sit down with someone who is learning is, Make a group out of all of the audio tracks and turn them down 5-10db.
People tend to start out too hot.
Good topic though.
about 70% of everything we get is way too hot for no reason.
bookerv12
Old 12-06-2013, 03:48 PM
mesaone mesaone is offline
This is worth a read, since I believe you're investing too much worry into this.... Gain staging in the box is a lot more forgiving, since you (usually) don't have to worry about signal loss and added noise.
Long story short, there's a lot more headroom in Pro Tools than what it looks like. And you can track a lot quieter than -6dB, and not suffer from the same issues that tape would have if tracked at a low level.
http://www.rcc.ryerson.ca/media/TECH...8-bitMixer.pdf
Old 12-06-2013, 03:49 PM
+1
In the template I use I turned all tracks down 9dB, so no matter what I can't start too hot.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 12-06-2013, 05:56 PM
zedhed's Avatar
zedhed zedhed is offline
http://www.musictech.net/2013/02/pro...-gain-staging/
http://www.harmonycentral.com/t5/Rec.../ba-p/34646453
http://therecordingrevolution.com/tag/gain-staging/
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 12-07-2013, 12:20 AM
JFreak's Avatar
JFreak JFreak is online now
Right. Of course that depends on the input material. Some do it with trim plugs as first insert; I mean, do the first rough mix with faders in unity and tweaking the trim pots until you have low enough levels and a decent starting point for your real mix.
A little math for you guys; few facts:
- 24 bit audio file in theory has 144dB dynamics
- best AD converters are in the ballpark of 120dB dynamics
=> therefore you have all the resolution in -24dBFS
Now that "yellow is the new red" is a really good rule of thumb. That hits the sweet spot and is kind of the old and still very useful 0VU level. And you don't necessarily have to aim for that "new red", staying below is perfectly fine.
And your monitor controller does have a volume knob, doesn't it?
Janne
Old 12-07-2013, 05:15 AM
Something missing here is apparent volume versus level. You can have a bunch of tracks or sessions that hit the same level on whatever metering you're using but some will sound louder than others. I run into that at times and just did with a remake of the Nutcracker Suite I'm doing. Every track hit the same level on the final metering but the Russian Dance was sounded quieter. What is needed is not just one type of metering for absolute level but also apparent level or whatever it's called - maybe rms metering? Watch peak metering for overs and rms for the rest. I think that's where PT11HD shines or iZotope Insight with the different metering schemes.
Jack
QAPLA!
Old 12-07-2013, 11:43 AM
JFreak's Avatar
I think the point here is recording levels and in that regard peak levels is what I consider appropriate. Mixing and mastering is a whole another story. Proper gain staging is especially important when you record, because there is no way undoing mistakes, except that you can always record again.
But yes, don't just look at the numbers. You need to know what the numbers mean. My last post assumed we're talking about peak meters and dBFS.
Janne
New metering - what is useful for gain staging? Blues Bird Pro Tools HDX & HD Native Systems (Mac) 15 11-15-2013 06:54 PM
Gain staging and the PT mixer kindkind Pro Tools 10 2 07-03-2012 08:17 AM
Gain Staging username_1 General Discussion 2 11-12-2010 01:41 PM
Gain Staging (i.e. +6 db = 0?) carmichael Pro Tools TDM Systems (Win) 2 03-15-2008 12:02 AM
Gain Staging wolfskin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-31-2005 12:02 PM
