Old 10-14-2021, 02:05 AM
Default Sticky labels for S1 colour keys.
Is anyone using label machine tape to label their user softkeys on the Avid S1? Bit hesitant because of glue residue that could mess up the surface. What's your experience with Dymo labels? Safe to use or "burnt in" sticky mess after a while?
What's safe to use to clean the S1?
Thanks!
Old 10-14-2021, 07:31 AM
its2loud its2loud is offline
Default Re: Sticky labels for S1 colour keys.
Thanks!
You could try vinyl stickers. No adhesive and it might stick to the buttons. Just a thought
Old 10-14-2021, 08:14 AM
Sorry, I should have mentioned that I need to use the "grey matter" below the buttons. I have two layers of softkeys set tup so the actual buttons are too small to carry those labels.
So the stickers need to go either next to the buttons or below.
Old 10-14-2021, 08:20 AM
Avery makes surface safe printable labels. I can’t say for certain they’d be safe on the S1 but you could always try them on the underside of the S1. That way if it does leave some residue (which I doubt) you won’t see it on top.
Perhaps someone else will chime in who’s used labels on the surface.
Personally, I would never use any glue type adhesive sticker on the S1. It’s bound to make some kind of mark over a long period of time stuck on the surface.
Old 10-14-2021, 08:43 AM
aaaah, good call on trying the underside. Hadn't realised that it has the same coating. I'll try that.
Thanks!
Frank.
Colour Assignable Keys in Multiple Avid S1s multi_kulti Avid S1, S3, Dock and Control App 7 10-24-2022 03:50 AM
Recalling layouts with track colour keys Frank Kruse Avid S1, S3, Dock and Control App 7 07-14-2021 09:36 AM
Keyb Midi Controller Gets "Sticky" keys w/ PM but not FW 410 tfrench4 Pro Tools M-Powered (Mac) 1 04-07-2008 10:33 AM
Sticky keys? Capi Baigorria 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-08-2004 01:42 PM
002, sticky keys JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2002 08:22 PM
