Eleven Rack with Ableton Live Lite 7
Is it possible to make the Eleven Rack work with Ableton Live Lite 7 ?
When I do try to record it has a doubling effect and playback only plays back the dry signal. |
Re: Eleven Rack with Ableton Live Lite 7
If playback only plays the dry signal, your input is set wrong. You want the Rig Output not the Guitar. Guitar is is the DRY guitar before any effects.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Input 1: dry guitar
Input 2: microphone Input 3/4: Stereo rig output input 5/6: Stereo digital in (AES/EBU or S/PDIF) Input 7/8: Stereo line in If you are using input 3/4 like you should be and only hearing a dry guitar, what actually have you got set up in the rig? (Start with one of he factory presets). |
I am plugging the guitar to the guitar input, and the usb out to the computer, then plug the headphones into the headphone jack on the Eleven Rack.
So on Ableton I should set the output 3/4 to on, and on the Eleven Rack I should set it to rig output?
The Albeton *output* should be set to 1/2 for the Eleven Rack main L/R output. For the record the Eleven Rack outputs are 1/2: main output L/R 3/4: Reamp L/R 5/6: Digital Output |
So I set the Ableton input 3/4 on for Eleven Rack, then what do I set for the Eleven Rack output so I can go usb into my computer to use Ableton?
Your question does not really make sense. Set what Eleven Rack output to? Where? "To go *into* your computer??... that is the 3/4 output from the Eleven Rack just mentioned. What else are you trying to record? If you mean what do you set the Ableton main/monitor output to, that is 1/2 on the Eleven Rack to hear your mix out the Eleven Rack main outputs. I've enumerated all inputs and outputs, you presumably have all this gear in front if you, Sorry but I am not getting why this takes/weeks or days to sort out, just play/switch inputs/outputs it should take minutes to sort out. Is there a deeper problem? Have you recorded music/audio before? Do you know how to use Ableton? What interface do you normally use it with? What exactly are you trying to record, from what source/instrument(s) plugged in exactly where on the Eleven Rack? How many simultaneous things/what exact ones are you trying to record? Last edited by Darryl Ramm; 08-24-2013 at 06:25 PM. |
I got it going. Sorry if I confused everyone with my question. I really appreciate everybody's help.
Whats missing in Ableton Live Lite? | daveparker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-21-2006 02:30 PM |
Ableton Live Lite 5 Digidesign Edition | Avid | Pro Tools M-Powered (Win) | 1 | 05-12-2006 09:19 PM |
Getting Ableton Live Lite 5.2 to work with Rewire? | bandagedhand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-27-2006 07:41 AM |
Ableton Live Lite not receiving midi | Sid Whiting | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-31-2006 07:18 AM |
Ableton Live Lite 5 Digidesign Edition | Avid | Pro Tools M-Powered (Mac) | 0 | 03-09-2006 08:08 PM |
