Old 01-03-2013, 10:45 AM
Esus Esus is offline
Default Video Out Not Working
Hello Everyone:
I'm revising a project I did a year or so ago, and I'm having problems with the video convertor box I used earlier.
I open my PT session, plug a FW400 cable from the front (it's a G5) to the device (a DAC-100, it's worked fine before). Composite video out of the DAC to external SD monitor. The monitor is getting a signal from the device (color bars in test mode).
When I go to Options>Video Out Firewire, I get a dialog "Pro Tools could not find a video device connected via Firewire. Check the connection to make sure it's powered on."
I've swapped out Firewire cables & power cycled both the box and computer--no luck. I wonder if I have a bad FW port on the computer?
If anyone has a solution, I would appreciate it.
Thanks!
Old 01-03-2013, 03:05 PM
Craig F Craig F is offline
Default Re: Video Out Not Working
could be a bad port, do you have a drive you can try on the port?
any updates to your system scene the last time you used it? I seem to remember a QuickTime upgrade that killed video out FW
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
working with video in PT musicman691 General Discussion 6 11-11-2013 03:34 PM
working on pc with video Kezzla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-15-2008 05:48 AM
Working with Video... jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-20-2008 04:07 PM
Working with QT video at 23.98 Hank5 Post - Surround - Video 9 12-11-2006 03:21 PM
Working with video vicwind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-28-2006 07:20 PM
