Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 07-31-2019, 07:22 AM
pikejono pikejono is offline
Default EQ and DYN not displaying on knobs or Master module
Hi All.
Strange one here:
Recently updated to 19.5.1 with no problems, the system was running perfectly for a week or so. Suddenly the S6 is no longer displaying EQ or DYN controls on the Knobs on the strips (when selecting via the EQ and DYN buttons on the processor module), nor are the parameters showing under the EQ/DYN sections under the home page on the MCM.
All parameters are available however via the INS button on the strips and in the MCM. Full parameter control works here no problem.
Pushing the EQ and DYN buttons does bring up the plug-in windows in Pro Tools, but the knobs on the strips are just blank (unless accessed via the INS). Pushing the EQ/DYN buttons even instantiates a default plug-in as normal.
Any thoughts on this would be greatly appreciated. Hoping not to have to do system restore.
Old 07-31-2019, 12:40 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: EQ and DYN not displaying on knobs or Master module
Greetings.
Which specific plugins are you trying to access dedicated EQ and DYN on?
Jeff
Jeff Komar
Old 07-31-2019, 01:57 PM
Hi Jeff.
Tested with stock plug-ins, EQ3 7-Band, and DYN3 compressor/limiter.
Old 07-31-2019, 03:57 PM
Are these Knobs configured as on Attention knob zones?
Jeff
Jeff Komar
Old 08-01-2019, 01:34 AM
Hi Jeff.
No Attention Zones set on the surface.
Old 08-01-2019, 02:57 AM
I have attached a few images here to illustrate.
Old 08-01-2019, 02:58 AM
A few more images
Old 08-01-2019, 04:28 PM
Thanks much! Can you please indicate what version of Pro Tools you are using in combination with S6 19.5.1?
Jeff
Jeff Komar
Old 08-02-2019, 02:15 AM
Hi Jeff.
We are running 2019.6.
An update though: I migrated the system drive over to a new OS installation (on a new physical drive) using a time machine backup this morning, and on booting onto the new drive the issue seems to have resolved!
I'm not sure what the problem was, but I will keep updating this thread should it return.
Old 08-02-2019, 07:33 AM
Thanks for the update! I’m glad to hear it is working now.
best,
Jeff
Jeff Komar
Master Module Won't Boot hixonjames Pro Tools | S6 6 02-09-2018 01:01 PM
Best way to wire footswitch to Master Module for talkback ? WildHoney Pro Tools | S6 3 09-18-2017 08:23 PM
S6 not recognizing any modules, including master module polyh3dron Pro Tools | S6 4 06-30-2016 07:14 PM
Master Module FAN NOISE rcutz Pro Tools | S6 11 07-29-2015 07:39 AM
PC main unit w/ clicky knobs want smooth knobs Brandonx1 ProControl, Control|24, Command|8 6 10-20-2008 12:34 PM
