EXTERNAL REVERB NOT ON BOUNCED FILE...
I remember seeing a post with something similar to this, but didnt read it and cant find it, but i was wondering if anyone has a solution to this? im using an MX200 and when i bounce, i get no reverb.
POWERMAC G5 2.5 GHz QUAD POWERPC 4.5 GB RAM OO2 RACK PRO TOOLS 7.1-cs10 MUSIC PRODUCTION TOOLKIT DIGIMAX LT WAVES SSL WAVES DIAMOND REASON 3.0 |
Re: EXTERNAL REVERB NOT ON BOUNCED FILE...
It depends on how you have the reverb routed, you need to have it assigned to a track.
Can you actually record the reverb to a a track? If so then it should record into the bounce, if not then it wont be in the bounce. It will just be an outboard effect and not within the loop of the bounce. I hope that makes sense. The other alt is to actually record the Reverb to a track just prior to the final mix and then bounce it. Dave
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
thanks for the reply, ill just get around it by burning it to my rack cd burner. i usually do that anyways, but for quick rough mixes and ideas i just bounce.
turn off low latency monitoring!
that did it, thanks.
Problem with Bounced file.... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-14-2008 06:29 AM |
Reverb Not Being Bounced To Disk | juke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 02-13-2008 11:42 PM |
bounced mp3 file longer than source file | chobbs | Pro Tools TDM Systems (Mac) | 4 | 01-24-2006 03:00 PM |
Can't burn CD from bounced file | 12bbb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-02-2004 10:19 AM |
Clipping on Bounced File | marksm | Pro Tools TDM Systems (Mac) | 3 | 01-04-2000 08:40 AM |
