New Mac for HD Native & PT11- help!!
Agonizing over Mac selection... There is a $2K swing between 12-core at 2.4GHz to 3.0 GHz for Mac Pro. Thinking I should be fine with 2.4, but would appreciate advice. Will be using Lynx 16. No video now. Not expecting to use a lot of VI. Projects are mostly bands who want to track together on 12-14 channels. Any thoughts would be appreciated. Cheers! Steve
Re: New Mac for HD Native & PT11- help!!
What Pro Tools core system do you already have, and do you plan on replacing it with a different core system?
If you already have an HD Native PCIe card, and want to get a new Mac, then that would limit you to a Mac Pro. If you do not have an HD Native system yet, then the HD Native Thunderbolt option would allow you to consider an iMac. If you already have a good moniter to hook up to a Mac Pro, then the iMac might not be what you would want. But if you don't have a good screen, the top of the line 27" iMac would give you a really nice screen and pretty good power for a native system. |
Thanks, Bruce. Currently working with PT8LE, 003R+, and MacBookPro. But just purchased PT10HD Native, and want to select appropriate computer that won't limit us too soon, which is why I am leaning to the 12-core MacPro. But I don't want to over invest in a computer that won't be needed. Are you suggesting that an iMac with Thunderbolt would be sufficient and will allow me to take full advantage of PT11? I thought that I understood that it was designed to take best advantage of the multicore system. - Steve
The Imac I7's are multicore systems with hyperthreading. It will show up as 8 cores. For what you're doing it should be plenty. The 12 core would be overkill.
I can do all with my 6-cores
Look here at the benchmars of the mac computer. You can also gownload a free copy of geegbench and test your benchmark of your current mac http://browser.primatelabs.com/mac-benchmarks I personally wont go Imac because this mac is not expandable Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
If you need something right now, and don't want to wait for the new mac pro(which has an unknown release/announcement date as of yet), I think it would be safer to go with a used mac pro(because it won't depreciate as fast as a new one will) or a thunderbolt imac. The i7 imacs are very fast. Aside from internal drive bays and PCIe slots, they basically perform as good or better than the entry level mac pro quads do.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Can I use AAX DSP plugins with PT11 HD Native? | BigDropz | AAX Plug-ins | 4 | 03-13-2014 11:14 PM |
Monitoring PT11 HD Native with no console? | kirkbross | Pro Tools HDX & HD Native Systems (Mac) | 6 | 02-19-2014 11:47 PM |
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
Possible to have 10.3.6 TDM and PT11 native on same machine? | mtung | Pro Tools 11 | 4 | 07-27-2013 07:11 PM |
PT11 HD Native with MacPro 3.1 | Jim Morris | Pro Tools HDX & HD Native Systems (Mac) | 2 | 04-09-2013 11:25 AM |
