Old 05-01-2012, 08:46 AM
sneakybeanz sneakybeanz is offline
Exclamation Pro Tools 9 "Access Violation 0x00000008"
Pro Tools has been running fine up until recently. I start to get this access violation message with the code "0x00000008" while on the ptools loading screen (particularly when it begins to load the plugins n such). If anybody can help me with this issue, it would be greatly appreciated. Thanks aviders.
Old 05-03-2012, 06:16 PM
paulreed paulreed is offline
Default Re: Pro Tools 9 "Access Violation 0x00000008"
most likely a bad/old pluginn...which one does it hang up on? try removing it and putting it in your unused pluginns folder. If the access violation stops, it was that pluginn, see if you can update it.
If that doesn't work try taking all of your non-avid pluginns out one at a time and test each time to find the culprit.
Old 07-01-2014, 05:16 PM
mattgbeatz mattgbeatz is offline
Win7 64 bit
16gig of ram
i5
pro tools 10 doing same thing
how do I stop non avid vst loading
please help .
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 thibault 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-22-2013 05:08 PM
Help with Pro Tools "Access violation occurred unable to read dll" issue dfeeley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2011 09:01 PM
Help with "Could not complete the exit command because Access Violation occurrred" keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-06-2010 06:24 PM
Help? sudden error repeats: "access violation occurred" jojo99 Pro Tools M-Powered (Win) 5 01-26-2009 09:20 PM
"access violation " protools can not make auto backup " nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-16-2008 03:54 PM
