[solved] can't start up for first time post-install (Win10/pt12.7)
hello dear DUCkers,
My dear old 2012 Macbook Air finally died, so I've just installed PT12.7 on Win10 on a Surface Pro 4, so i can do some editing of existing sessions. I have no compatible audio interface (my Apogee is firewire), but since I'll just be editing, the headphone output should suit my needs fine. However, when I start up, I get the error message "The selected audio device could not be initialized. Please choose another audio device. [Quit] [OK]" I click OK, and next get an AAE -6117 error. If i click OK on this, I get the previous error again, and it's an infinite loop of these two. So all I can do, finally, is select Quit. I tried starting up holding the N key to select an audio device, but it has no effect. Can anyone help me get started up, with the headphone jack as my output? EDIT: ok solved! i had to install the free ASIO4ALL driver. I'm leaving this here because it might be useful to others. thanks in advance ~peter in athens
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies Last edited by huzzam; 01-25-2019 at 02:32 AM. |
Re: can't start up for first time post-install (Win10/pt12.7)
Hey
You need a virtual driver that mimics a audio interface driver like asio4all as on windows machines you cant use the onboard audio card without a virtual driver like asio4all. Many members use that here on the forum until they get a real interface so safe but not a great longterm solution for PT. I would also look for a Usb/thunderbolt to FW adapter if it exist for PC. Download free version and try and I bet you will be up and running within minutes www.asio4all.com
Thanks SouthSideMusic! ASIO4ALL did the trick!
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
Re: [solved] can't start up for first time post-install (Win10/pt12.7)
Glad to help and Happy it worked
PT12.7.1 sluggish GUI over time+ Crazy long post session computer shutdown.. | gavin.g | Pro Tools 12 | 7 | 06-13-2017 04:30 AM |
PT12.6 on Win10, how's it running | YYR123 | Windows | 5 | 11-24-2016 08:00 AM |
How's PT12.5 and 12.6 running on Win10? | YYR123 | Windows | 6 | 10-29-2016 12:08 AM |
What version of PT12 are you using? Are You using Win10? | senghor | Pro Tools 12 | 18 | 06-22-2016 10:01 AM |
PT12 - TCEX, PnT units, clips start-end time code display | Kuba Pietrzak | Post - Surround - Video | 6 | 03-09-2016 01:13 AM |
