Old 02-18-2011, 08:58 PM
KingFish KingFish is offline
Default Venue D Show 2.9 Delay Compensation Not working properly.
Assigning All Drums out 2 Stereo Groups.
1st Group, no Inserts
2nd Group Insert a Smack Compressor, and FF6 EQ
Pulling up Kit sounds with only Group 1 Fader up, dial in kit, then start to pull up Group 2 for Paralel Compression
Kit is Phased.
Workaround, is to insert same plugins into Group 2, but "Back off all parameters" so that the plugins aren't coloring the sound, and the kit remains punchy and Phase coherent.
Any one else encountering this ?
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 02-18-2011, 09:34 PM
Nicolas Lowman Nicolas Lowman is offline
Smile Re: Venue D Show 2.9 Delay Compensation Not working properly.
Did you add an additional "align" channel with nothing patched to the input? This "align" channel must be assigned to your 1st Group, 2nd Group, and the Stereo Buss. This is what tells the computer to do the compensation.
Old 02-18-2011, 09:47 PM
SuperReverb SuperReverb is offline
Default Re: Venue D Show 2.9 Delay Compensation Not working properly.
Kit is Phased.
Although Nicolas is right, I find the workaround that you've troubleshot, actually sometimes to be a much quicker workflow, building a mix quickly, to just insert the same plugins on both groups, making the parameters inactive on one of the groups. And it's just as effective.
Old 02-18-2011, 11:54 PM
I'm not a "Live Guy" - can you walk me through adding an "Align Channel" and assigning it to say "Group 1, Group 2 & L&R Mix"
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 02-19-2011, 03:40 AM
mariojorgeandrade mariojorgeandrade is offline
Hi.
It's really easy.
Robert Scovill explains that in one of the webinars.
This "Align Channel" makes the delay compensation works properly in that situation.
Just pick a unused channel and patch it to both subgroups (the ones you mentioned, one with processing plugins, the other "clean") and to the L/R mix and the delay compensation will work properly.
Good luck.
Regards,
MJ
Old 02-19-2011, 09:13 AM
Thanks MJ - That sounds simple!
We'll test today.
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 02-22-2011, 08:59 PM
ams9 ams9 is offline
So if you are doing multiple parallel compression groups like a drum parallel/clean and vocal parallel/clean sending only one align channel to all of these and the stereo buss would work correct? you would never need multiple align channels?
Old 02-23-2011, 07:58 AM
Jason Stygar Jason Stygar is offline
Yes... Essentially this is what we do...
We just pick a channel out of the way and assign it to all the groups and the L/R buss.
Some may argue that we're punishing the time of arrival of everything when we don't need to, which is correct, but it's something we don't have to think about. Everything is aligned.
So just grab a channel. Assign it to everything. Continue mixing.
That's the how... For the why, I'd watch the webinar (for which the name I can't remember)...
Jason
Old 03-22-2011, 08:52 AM
Audioartist Audioartist is offline
Does not work with variable groups if you assign to more than one group, what a shame. And if your using monogroups they can not be linked to use with stereo plugins.
I hope there will be an update soon.
Venue Delay Compensation Tigerspill VENUE Live Sound Systems 5 02-21-2013 09:00 AM
HD Native Delay Compensation not working! nuancerec Pro Tools HDX & HD Native Systems (Mac) 10 01-24-2011 04:12 AM
Automatic Delay Compensation not working like it should Edgur Pro Tools TDM Systems (Mac) 8 08-19-2009 07:25 AM
Delay Compensation Has Stopped Working voce Pro Tools TDM Systems (Mac) 5 07-08-2009 12:32 PM
Display-mix window show- delay compensation view Yodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-18-2005 01:16 PM
