#111
Re: Sample Rounding Issue!!!!
just sayin' !!!! show me the Money !!!
#112
Agreed
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions |
#113
A nightmare!!!!!!!!
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#114
Groups of notes get misaligned when I use the cut/insert time feature also.
The other night all I wanted to do was cut a couple bars here and there, insert a drum clip and experiment with a couple different arrangements Went back and checked the alignment of each track and random note groups all got shifted out of time. After what was supposed to be quick & easy cuts & inserts. Up all night. I finally got lost in all my undo/redos that I just started all over with the original session file & bounced the master down to audio. Then chopped it into sections then arranged everything with the shuffle feature on. All just to insert a drum pattern at the beginning and cut the verses in half. |
#115
Avid has been aware of this issue for some time. http://avid.force.com/pkb/articles/e...ow_To/en430955
Unfortunately their solution (to use ticks instead of samples) does not work. |
#116
I don’t remember a version of PT that didn’t have the sample rounding issue. Granted I started around version 6 or maybe 7, don’t totally remember, but it seems like this has always been an annoying issue.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
#117
Since I switched to Pro Tools with v6 in the 2004 I always had to do with this issue. But while this happened with audio clips only, with v12 it showed on midi clips as well. This is very annoying because when moving or copying midi clips sometimes they lose the first note/chord of the clip.
#118
#119
#120
The worst part, is when someone who is not familiar with this issue consolidates their tracks after doing crossfades and not checking them. The little "sliver" of audio that you can see at the sample level ends up getting 2 crossfades super close together on each cut. This will create a clicking/snapping sound and its because of duplicating and the region not being exactly on the line from this issue. There are micro holes... Doing quick arrangements with lots of audio is also a pita. There are always gaps where ever the edits are. I have to constantly go in and blow up where the clips are butted against each other to fix all the little holes.... Don't get me started with midi..... notes disappearing etc.... Spikes with VI's.... TIME TO FIX!!! Embarrassing!!! "We Cant reproduce this". Yeah Right!!! I thought this was PRO tools...
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3 Macbook Pro, 2019 (15,1) Mac OS 12.7.2 Monterey,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3, Apollo 8 Silver,TwinX. |
Sample Rounding | budda963 | Pro Tools 11 | 1 | 07-08-2013 06:07 AM |
sample rounding error in pro tools 10??? | DarkDayz | Pro Tools 10 | 6 | 11-02-2011 03:22 AM |
PT and Sample Rounding WILL cause Issues when Copying | 25ghosts | Pro Tools TDM Systems (Mac) | 7 | 07-01-2011 02:25 AM |
Sample rounding issues | bigdoghat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-13-2007 08:20 AM |
Sample rounding, ticks, etc | voce | Pro Tools TDM Systems (Mac) | 1 | 08-03-2005 05:26 AM |
