A question for DigiTechSupt
I got some errors after running the DigiTest™ 5.02 in ten attempts. Here are the details of the failed ones:
__________________________________________________ _________________________ 1st failed attempt: S/PDIF Toslink Internal Loopback Test (44.1Khz) Channel 1: (Failed 5 times) Pattern not started S/PDIF Toslink Internal Loopback Test (48Khz) Channel 1: (Failed 3 times) Passed S/PDIF Toslink Internal Loopback Test (44.1Khz) Channel 2: (Failed 5 times) Pattern not started __________________________________________________ _________________________ 2nd failed attempt: S/PDIF Toslink Internal Loopback Test (44.1Khz) Channel 1: (Failed 5 times) Pattern not started ($000000) S/PDIF Toslink Internal Loopback Test (48Khz) Channel 1 : (Failed 5 times) Pattern not started ($000000) S/PDIF Toslink Internal Loopback Test (44.1Khz) Channel 2: (Failed 4 times) Passed S/PDIF Toslink Internal Loopback Test (48Khz) Channel 2 (Failed 5 times) Pattern not started ($000000) __________________________________________________ _________________________ 3rd failed attempt S/PDIF Toslink Internal Loopback Test (44.1Khz) Channel 1: (Failed 4 times) Passed S/PDIF Toslink Internal Loopback Test (48Khz) Channel 1: (Failed 3 times) Passed __________________________________________________ __________________________ Do i have anything to worry about?. Thanks in advance. Techs: Mac G4/400 AGP MacOS 9.0.4 |
Re: A question for DigiTechSupt
I am not sure what the S/PDIF Toslink Internal Loopback test does.
Are you experiencing problems with your hardware? Do you have a digital device equipped with optical S/PDIF so you can try transferring into Pro Tools? If you are not experiencing any problems while using Pro Tools, I would not worry about it. However, if you are unable to transfer in via optical S/PDIF, then please contact tech support via phone at: 650-842-6699 Brent |
I'm not experiencing problems with the hardware however i' get every once and then at launching , any kind of error that i do not remenber now. I never had any problem in a session.
I 've not anything connected in the S/PDIF just now, but maybe i will. |
iLok Question - DigiTechSupt? | dmsaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2006 11:19 PM |
DigiTechSupt - Question regarding DigiLink Cables | Imagine | Pro Tools TDM Systems (Mac) | 0 | 07-16-2004 12:11 PM |
Anyone seen this? Please HELP if you can. DigiTechSupt? | RobMacki | Pro Tools TDM Systems (Mac) | 3 | 06-26-2003 09:03 PM |
Good Question For DigiTechSupt | Jerry Finklestien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-06-2002 05:51 PM |
Help!! DigiTechSupt question | Argeiphontes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-27-2000 04:51 PM |
