Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 12-18-2015, 08:46 PM
STSCRUSHER STSCRUSHER is offline
Default Just added Mout 2408mk3 to my HD192 rig running PT10, problems with 2408mk3
I just purchased a used 2408 mk3 and hooked it up to my pci424e card. I got it to work yesterday no problems. I took it to a studio to track today and it gave me nothing but problems.
Sometimes the top button on the right "meters" would flash and I couldn't get it to operate it. my computer recognized it, I ran the motu set up for the audio, set the appropriate paths in the digi I/O in PT 10. When I would record arm a track; the dialog where you can change the automation/turn of the voice for the track would go gray. When I assigned an output for that track, the VU meter would just peg. I would switch to the HD192 in's and outs...no problem. Sometimes when this was going on the "meters" light would light up....sometimes it would flash.
Eventually; I restarted my computer several times and it started acting funny, and now it won't boot. It cycles on, I can here the optical drive spin, then it cycles again....no display. So i'm pretty sure it's my video card.
My question: Can the video card being bad cause problems with my audio Rig? I'm popping in a new video card in the morning over at the studio. I'm hopping that will fix the computer problems....but if it doesn't fix the 2408mk3 from acting strange...gonna have to be on my toes.
Thank to anyone that reads this, with an extra special thank you to anyone who posts. My but was pretty tight today, just waitin for tomorrow.
Old 12-19-2015, 07:23 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Just added Mout 2408mk3 to my HD192 rig running PT10, problems with 2408mk3
I can't see the Motu causing that, no. Sounds like there were underlying issues with the computer..
Check for bubbled capacitors on your motherboard too, also could be a power supply issue.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 12-19-2015, 08:12 PM
Yeah, I figured it was a computer issue and not the 2408. I had no problems with it before I moved it. I went to a shop, put in a new video card, took my PC back to the studio and started up no problem. Motu 2408 acted completely normal. Strange how a wonky video card can throw everything off.
I was upset. I've got a 4 piece kit with 13 mics set up, and can only borrow km184's for the weekend. I lost a day, but should get all my drum tracks finished tomorrow. Thanks for your reply.
Old 12-20-2015, 05:35 AM
JoelG's Avatar
Glad you got it figured out. Bummer about the timing, kinda ruins the moment!
Joel
Jam Space:
Home:
Rig:
Old 12-20-2015, 12:04 PM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Upgrading the ageing and underpowered original gtx120 on a 4,1 Mac Pro helped with a couple of issues.
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
pro tools 9 and motu 2408mk3 hotsihombing Windows 9 04-23-2012 06:27 PM
PT9 and Motu 2408Mk3? derF macOS 0 12-09-2011 03:28 AM
Pro Tools 9 and 2408mk3 hardware ChicoB macOS 4 03-28-2011 12:07 AM
The 2408mk3 and Logic?...A step up from 001/PTLE? Loftman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-07-2003 08:02 AM
HD 96 I/O vs MOTU 2408mk3 fmckinnon Pro Tools TDM Systems (Mac) 5 10-04-2002 08:46 AM
