Avid HD I/O questions:
Howdy -
I'm very close to getting an HD Native setup, but I can't decide between the HD 8x8 or the 16x16 (analog). For the shorter term, the 8x8 makes much more sense (I'm doing mostly ITB mixing with a few pieces of outboard). However, for longer term growth, the 16x16 is probably a good idea. The thing I can't figure out is why the 8x8 only has one expansion port. On the back of the 16x16, the picture shows 4 bays filled (2 by eight-channel input cards, 2 by eight channel output cards). Why does the 8x8 only have one available for expansion - shouldn't two bays take care of the I/O?? If I could buy the 8x8 and later add 2 option cards to get it up to 16x16 if needed, this would be the best situation. I guess I assumed these were the exact same boxes with different cards in them, but perhaps they are different boxes? Or I'm missing something easy... Thanks
www.thestudiofiles.com |
Re: Avid HD I/O questions:
Looking at the specs again of the two boxes, I guess the 8x8 also has an 8-channel TDIF and AES card in it.
Is it possible to later remove that card and put in two analog cards (thus effectively making it into a 16x16 analog, just a little more expensive than buying it that way in the first place)?
It says one bay for expansion which to me implies that only one more card can be added, either ins or outs, not both I wouldn't think.
A couple of things to consider:
1. It's not just a little more expensive to add cards later, it's a lot more expensive. You'd be looking at about $2600 to add 2 more cards later ($1295 each). Whereas if you buy the 16 by 16, it's only $1000 more than the 8 by 8. 2. Besides the cards, the 16 x 16 still includes 8 channels of adat in and out (or spidf optical), as well as 2 channels in and out of AES and Spidf. This is over on the right side and is standard regardless of the card configurations. Though it's still a max of 16 in, 16 out, it still gives you these digital options. Unless you really need a lot of digital I/O at one time, this unit seems like the best overall value. Seems worth the extra $1000 to get it all up front. You can see a good picture of the back of the unit on the Sweetwater site. Click on the picture to enlarge it: http://www.sweetwater.com/store/detail/HDioAnalog |
Yeah, in terms of $$ it makes sense to go big now.
It just seems like a lot of empty channels now (since I have little outboard), but I guess as a solid base for expansion over the next decade, it's a good investment. sold!
Plus buying it as part of the HD Native bundle discounts everything even a little more. I'm hoping very soon to get the Omni bundle myself.
The two questions that Avid don't want to answer | radardoug | macOS | 31 | 03-28-2013 02:09 AM |
Avid I/O Questions... | Bill Denton | Pro Tools TDM Systems (Mac) | 9 | 02-21-2011 07:24 AM |
Mackie and Avid, questions? | TCM | General Discussion | 5 | 11-10-2009 12:46 AM |
AVID MOJO / AVID XPRESS DV / PT 7.0 Questions | Echo studios | Post - Surround - Video | 5 | 01-07-2006 12:06 AM |
Trying to build obsolete AVID - many questions... | houseofrecords | Post - Surround - Video | 2 | 03-25-2001 03:10 PM |
