Old 02-03-2016, 05:04 AM
tooold's Avatar
tooold tooold is offline
Default New memory locations window problem and solution
I know there was a problem with the memory locations window a while back.
I just had a different scenario - opened a session I'd worked on yesterday, all memory locations were in the timeline, but none in the ML window. Closing and reopening the window didn't do anything.
Trashed prefs, everything works fine now.
Just putting this up in case someone has the same problem.
2015 nMP 64Gb RAM, OS 10.14.6, PT Native 2019.6, Metric Halo ULN-8, LIO
http://www.mylescochran.com
Old 02-03-2016, 05:41 AM
Drew Mazurek's Avatar
Default Re: New memory locations window problem and solution
Best guess on what happened:
You (inadvertently I guess) deselected the ML "types" you wanted to show by clicking on their icon in the ML window. When you do this, they will grey out and whatever type of ML you deselected will no longer be shown in the ML window although they'll still be shown in the ruler.
When you trashed prefs you reset this "filtering"
www.drewmazurek.com
Old 02-03-2016, 05:46 AM
tooold's Avatar
Thanks, Drew.
It wouldn't be the first time I've done something without being aware of it! It does make sense and clicking on the marker filter produces the same result. Something else to file away under "when strange things happen".
Old 02-03-2016, 05:52 AM
It wouldn't be the first time I've done something without being aware of it! ................Something else to file away under "when strange things happen".
Both are daily occurrences here!
www.drewmazurek.com
Memory Locations window won't show DeanWW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2012 05:31 AM
Disappearing Memory Locations Window roderickelms Pro Tools TDM Systems (Mac) 8 03-14-2012 02:23 PM
Memory Locations Window Help!? Julian S. Pierce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-28-2010 07:09 AM
Memory locations window "apple 5" problem foggch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2010 12:07 PM
Memory Locations window size in PT8 squidsquad Pro Tools TDM Systems (Mac) 0 04-27-2009 04:56 PM
