Old 05-17-2010, 04:39 PM
pechinma pechinma is offline
Default mbox 1 - mic works only when interface set to line or inst
hi
i have a mbox 1 focusrite. when i connect my shure 48-mic to it and set "mic" on the selected port, it doesn't make a sound. when i set it as "line" or "inst" it works though but not with a very good result
i've tried both ports and its the same. i have digidesign ASIO driver.
anyone know how to help me ?
Old 05-17-2010, 05:00 PM
DigiTechSupt's Avatar
Default Re: mbox 1 - mic works only when interface set to line or inst
What type of cable are you using? It sounds like your cable has a 1/4" connector on the end you're plugging into the Mbox. You need an XLR cable if you want to go into the Mic input...
Avid Audio Tech Support
Support FAQ
Old 05-17-2010, 05:18 PM
thanx man...yee im an idiot haha. i have en XLR connector at the end of the mic, but of course i had a 1/4"connector adaptor at the end of it!! i will remove that one and probably it will work. at another hour though when the neighbours tends to be less annoyed (1:20 am here)
noisy Line/Inst switch on digi 002rack kunal FireWire and USB Audio Interfaces (Win) 5 05-20-2013 12:03 AM
Inst/Aux track: Mach 5 works, Stylus, etc... does not BookSix Pro Tools TDM Systems (Mac) 2 04-23-2007 06:02 PM
Line versus Inst jb61264 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-07-2005 10:41 PM
MBOX line vs inst??? muse6638 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-16-2005 08:28 PM
Anyone else's Mbox noisy on line or inst? BookSix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-13-2004 06:49 PM
