Old 02-25-2012, 10:14 AM
mbahnmil mbahnmil is offline
Question Solo/Mute a given track without having to find and click on it every time?
Hey all,
I'm working on a song clone, and I have the CD for the song I'm working on, so I ripped it and pulled the song into Pro Tools. In order to do the clone, I'm using several EastWest products and maybe at some point will need tracks for live instruments.
Point is, I'll have a lot of tracks, and the best way for me to work on a clone is by often doing an "A/B". That is, while I'm working, the Song track is muted, but when I want to listen to what I've got going on versus what the song is doing, I have to un-mute the Sang track and solo it as well. and then back and forth.
This isn't so terrible as long as my cursor is on the Song track. I can just hit "Shift-S, Shift-M" to toggle between listening to the Song track and listening to what I'm doing. What I'm wondering is ... is there a way to do that without having to find my song track and then click on it? Like maybe a way to mark the track so that I can use a hotkey to get to it... or something to that effect?
It just gets tedious to have to find it every time when I'm working farther down the window.
Many thanks for any help!
-m
Old 02-25-2012, 10:25 AM
Question Re: Solo/Mute a given track without having to find and click on it every time?
I guess a more direct question might be: how can I audition the Song track at the current cursor position without having to find the song track?
Old 02-25-2012, 10:41 AM
Default Re: Solo/Mute a given track without having to find and click on it every time?
... I could make the Song track the first track in the track list if that would help...?
Old 02-25-2012, 10:54 AM
.... or how about auditioning a selected track? I could just leave the Song track selected while working elsewhere, if there is some key combo that would allow me to audition the selected track?
Thoughts, anyone?
Old 02-25-2012, 02:40 PM
daeron80 daeron80 is offline
There's a workaround but it has its own drawbacks, as usual. You can give the reference song track a stereo bus input, and set all your other tracks to output to it. Put the song track in record. Now you can toggle between the reference and your mix with the keyboard shortcut for Auto Input Monitor.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-25-2012, 03:43 PM
The Weed's Avatar
The Weed The Weed is online now
What about using groups?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-25-2012, 04:59 PM
daeron - what are the drawbacks
Weed - how would I use the groups? what are the shortcuts that would facilitate it?
Thank you both!
Old 02-26-2012, 10:18 AM
The Weed's Avatar
Group the tracks - not the regions - in your mix, make sure Solos is checked under Linked Within Groups and make sure the Group is activated. Make sure Solo is unlatched under Options (Options>X-OR [cancels previous solo]) and that Timeline Insertion/Play Start Marker Follows Playback is unchecked in Setup>Preferences>Operation ("N" toggles this on or off when in Commands Focus Mode). Now highlight a section you want to listen to or place your cursor where you want to play from, click the "S" on your reference track and play. As you're playing down click an "S" in your grouped mix. This should allow you to solo the reference track and then the mix and vice versa. Worth a try anyway.
Cheers,
SonoBus
Old 02-26-2012, 04:57 PM
The drawback of putting the song track in record are
1) You can't record anything without erasing that bit of the song track. Well, not really erasing, but you know what I mean.
2) Every time you open the session, you have to remember to put the song track in Record before you can hear your own version.
David J. Finnamore
[IMG] code is Off
A way to mute a track while un-muting another track w one click? DrummerGuy09 Tips & Tricks 7 06-12-2022 07:57 PM
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
Track Record Enable/Mute/Solo shortcut keys? maufau Pro Tools TDM Systems (Mac) 2 07-06-2008 10:11 AM
Why would one track not mute when another is in Solo Brad Gillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2007 02:44 PM
Solo/Track Mute Problem JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2003 08:19 AM
