Old 03-16-2008, 02:55 PM
lucio matarazzo lucio matarazzo is offline
Default Still the same bug in PT 7.4!! For DigiTechSupt
Hi.
Last year I started a thread
<http://duc.digidesign.com/showflat.p...umber=1159778> about an editing bug in PT 7.3 (it was also in PT 5.0, solved in 5.1 and still present in 6.x!!!).
The DigiTechSupt was able to reproduce it and promised to fix it.
I've noticed that the bug is still present in PT 7.4
I don't know what to say!
Any tip?
Thanks in advance
LM
Old 03-23-2008, 05:35 PM
Default Re: Still the same bug in PT 7.4!! For DigiTechSupt
No one interested to?
DigiTechSupt?
Old 03-25-2008, 05:33 PM
bump!
LM
Old 04-18-2008, 09:56 AM
Hi.
Any tip?
Thanks in advance
LM
Re-bump.
I need an answer, please.
Thanks,
LM
Old 04-18-2008, 10:08 AM
Slim Shady Slim Shady is offline
but report form
I wouldn't hold your breath though. There's lots of 7.4 bugs yet to be addressed. It seems that all of Digi's resources are working on the 10.5.x compatible release first, then they'll probably get to the cue of bugs (and hopefully some will be addressed in the 10.5 release...) I don't know that for certain, but I think it's a logical guess of what's going on over there because there have been several major bugs discovered in 7.4 and none have been fixed yet.
Old 04-18-2008, 10:50 AM
DigiTechSupt's Avatar
but report form
Slim is pretty much on the money on that one.
There are several editing bugs that we here in tech support are pushing to get fixed, but resources are not as available due to the upcoming Leopard release.
Avid Audio Tech Support
Support FAQ
Old 04-20-2008, 01:16 PM
Thanks for your reply.
Hoping to have good news from the Leopard release: if you work on sessions with thousands of regions and crossfades to manage, you could understand how annoying that bug is.
LM
PS: Slim thank you for your reply!
Old 10-03-2008, 02:40 AM
Thumbs down Re: Still the same bug in PT 7.4!! For DigiTechSupt
Hi.
Leopard release has gone. This bug is still alive!
Can we hope this bug could be fixed in PT8 version?
LM
Old 10-03-2008, 10:34 AM
You'll have to remind me which bug you're referring to, as links to the old DUC no longer work.
Support FAQ
Old 10-14-2008, 05:56 AM
This was my old message (05-17-2007):
Hi all.
Some years ago I started a 3D on an editing bug on PT 5.0. It was solved in PT 5.1 but "appeared" a new time in a "similar version" in PT 6.x since now in 7.3.1.
Scenario:
Options-> Automation follows edit ---> enabled
Two contigues regions (#1, #2), shuffle mode.
If I made the region #1 shorter (with trim tool on the right bounder), the region #2 shifts on the left and the same happens to its automation (i.e. volume level).
BUT
If I made the region #1 longer (with trim tool on the right bounder), the region #2 shifts on the right and the same
DOESN'T happen to its automation. The automation stays in its original position.
If you have 1 thousand regions to manage and this bug is really a disaster!!
Adding all automations later (when the regions are "fixed") is not a good job if you have to find regions working also with automations (i.e. editing in classical music).
Please try and report any suggestion.
Thanks in advance.
LM
And this was the DigiTechSupt reply (05-21-2007):
I've been able to reproduce this and will log it for a fix.
I have to say that now, in 7.4.2 also if I made the region #1 shorter (with trim tool on the right bounder), the region #2 shifts on the left BUT the automation of region #1 "losts" the point on the right bounder!
If you have many automations, it is really a disaster!!
Thanks for the attention.
LM
Attn: DigiTechSupt: Cry 4 Help PT8 fooloof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-01-2012 07:36 PM
DigiTechSupt otobot Pro Tools 9 3 01-08-2011 11:34 AM
DigiTechSupt binty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 07-22-2010 04:52 PM
Looking for digitechsupt...i need you help again.. Antho141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 10-08-2009 08:14 PM
Anyone seen this? Please HELP if you can. DigiTechSupt? RobMacki Pro Tools TDM Systems (Mac) 3 06-26-2003 10:03 PM
