Re: Converting VHS to Digital format
If you have access to an Intensity Shuttle you can try it yourself. Connect a VHS deck to the analog inputs and try recording something on the computer. It doesn't matter which format you use to capture, DV or otherwise, it just plain doesn't work. Last edited by V5V; 07-11-2018 at 11:33 PM. |
The suggestion to continue using the DV format when recording to the computer (via SDI, SDI to HDMI or Firewire) was to maintain quality. The DV devices digital stream saved as a digital file with no processing for minimal quality loss. Sorry the Intensity Shuttle does not work. I use several different BM IO cards in computers around here but they are used for monitoring not capture. Andrew |
Help needed with converting PT 10 to 9 format... | elangab | Pro Tools 10 | 2 | 06-09-2012 03:08 AM |
converting wav format into MP3 | mastermorris | Tips & Tricks | 10 | 02-02-2010 12:26 AM |
Converting PTS files to WAV or another format | Valkhorn | Pro Tools TDM Systems (Mac) | 2 | 11-17-2007 07:23 PM |
Converting a SDII file from mac format to pc..HELP | KemikAL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-05-2003 02:55 PM |
Converting a SDII file from mac format to pc..HELP | KemikAL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-05-2003 01:55 PM |
