Command 8 and Cubase
Anyne one know if the command 8 is compatible with cubase? I wanna get the digi002r and the command 8 for audio but still use cubase for sequencing but need to know if the control surface works with cubase. I know the digi 002 works with cubase.
Re: Command 8 and Cubase
Hello,
The command 8 will work with Cubase! in stand alone mode as a midi controller!! but you will have to set this up yourself for your own needs!!! a bit tricky for the midi shy. The Mackie control is ready out of the box to control most audio apps. Buy command 8 and use Pro Tools as your DAW! BFN Chris
Cubase command 8 midi map here | xsdata | ProControl, Control|24, Command|8 | 31 | 01-05-2012 06:45 AM |
Command 8 And Cubase | shlomiabo | ProControl, Control|24, Command|8 | 6 | 11-01-2011 07:51 AM |
xml command 8 for cubase 5...help...i can't find it... | celestian | ProControl, Control|24, Command|8 | 0 | 07-09-2009 06:08 AM |
Command 8 with Cubase 5 with Vista...help.... | celestian | ProControl, Control|24, Command|8 | 0 | 07-02-2009 04:53 PM |
Digidesign Command 8 with Cubase Studio 4 - HELP!!! | stevethebeeline4 | ProControl, Control|24, Command|8 | 0 | 05-17-2008 07:52 AM |
