PT 10 + Error message 6101 constantly at same spot in session
So im basically unable to continue writing in the current session i was working on as i keep getting the h/w buffer error message at the same spot in my session... All my music is tracked in Reason 6 and rewired into one instrument track in Pro Tools 10.0.1. The only plug-in im running in PT is Izotope Ozone 4 on the master track.. I've tried going back to version 10.0.0 and still get the message constantly at the same bar. My buffer setting is at the highest i can go and i have set the CPU usage limit to its max.. My computer is a Macbook 2.1ghz with 4 gigs of ram. I have ran much larger sessions in the past with no problems... I can't figure out for the life of me why this one is being so problematic, especially at the same spot. I did check activity monitor and it says the PT is consuming 150% cpu... im not sure if this is normal or not.. any suggestions to help me fix this issue would be greatly appreciated...
Re: PT 10 + Error message 6101 constantly at same spot in session
Try Bouncing The Audio From Reason 6 And Pulling It In To PT, Other Than That, It Sounds Like You Have A Corrupt Audio File In Reason 6... I Know, It Plays Back In Reason 6 Fine, But PT Might Not Like It Via Rewire..
Funny I had the same issue with Reason running within PT10 last night, made Reason inactive and the problem stopped, of corse that does not solve the problem...
PT9 6101 error message and now doesn't open at all | vjferrara | macOS | 0 | 07-31-2011 03:07 PM |
Error Message 6104 and 6101 | ckahle33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-24-2011 04:08 AM |
error message (-6101) | Chickenhawked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-04-2011 10:40 PM |
6101 error message | scott bourgeois | Pro Tools M-Powered (Mac) | 1 | 05-26-2009 01:10 AM |
error message 9129 and 9093 constantly !!!!!!!! | dizzove | Tips & Tricks | 1 | 06-13-2005 09:20 AM |
