Old 03-04-2012, 11:00 PM
Samba Samba is offline
Default How do I duplicate properly?
Hi!
When I duplicate a bar, sometimes the length of the duplicate i make falls short of the end of the bar, or goes too far over the end of the bar.. Why does this occur?
To make the duplicate, I highlight the bar (or bars) and press Command+D..
i'm running PT9 on a MacBook Pro. However this has often happened since i started with PT7 on windows
thankyou
Old 03-04-2012, 11:07 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: How do I duplicate properly?
Are you talking about audio or midi ?
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 03-05-2012, 12:10 AM
zedhed's Avatar
zedhed zedhed is offline
Are you in grid or slip mode when selecting bar?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-06-2012, 08:13 PM
Fabdickson Fabdickson is offline
Don't Select The Region, Select The Bar (Drag From 1.1.000 To 2.1.000 In Grid) .... Then Duplicate....
Old 03-12-2012, 01:11 AM
Thanks Fabdickson,
how do i do that? I'm dragging the audio "block" with the hand tool while i press alt, and it still runs over, as it does when i duplicate..
Old 03-12-2012, 01:13 AM
Chris
Hi Chris,
thanks for responding.. i'm talking about audio..
Old 03-12-2012, 01:14 AM
hey zedhed.. love the catchphrase!!
im in grid mode
Old 03-12-2012, 01:21 AM
PD-John PD-John is offline
Originally Posted by Samba View Post
Thanks Fabdickson,
What Fabdickson means is to select a fixed number of beats on the grid using the selector tool. By doing this, you'll ensure the audio will duplicate in time with the grid. If the audio region boundaries falls slightly before or after a gridline, you may find that when you duplicate it, the audio will go out of time.
Hope this helps.
Old 03-12-2012, 04:27 AM
Hope this helps.
Hi PD-John,
Do you mean the hand?
Old 03-12-2012, 04:28 AM
I still don't get it!!!
[IMG] code is Off
How to duplicate clips... that actually duplicate physical files? mooquu Pro Tools 10 4 06-04-2014 03:28 AM
Duplicate Out torpedo1 Tips & Tricks 5 04-23-2009 01:53 AM
Duplicate bug? sykes Pro Tools M-Powered (Mac) 0 12-01-2007 01:28 PM
Duplicate? powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-30-2003 06:28 PM
Duplicate or not? Anibal Tips & Tricks 1 11-24-1999 09:10 AM
