Old 09-12-2020, 11:05 AM
jrs320 jrs320 is offline
Default New Mac Pro Doesn't See Avid Omni HD Native Thunderbolt
I bought a Mac Pro 2019 and am trying to get Pro Tools up and encountering problems. No surprise. Hoping someone can help. Here are the facts.
I migrated my data from my Mac Pro 2013 when I first turned on the new computer. I’m running:
PT 20.5.0.207, (2020.R1.0),
My hardware is an Avid Omni HD Native Thunderbolt and I have an Apple Thunderbolt 3 to Thunderbolt 2 adapter so I can plug it in.
When I boot PT it goes through its startup process and at the end it tells me it can’t find the Avid Omni.
It also doesn’t see my Waves plugin licenses, but I’ll get to them after I get the app working.
That’s it. I’m happy to fill in any info that might help, just let me know what you need.
Thank you all!!
Jon
Old 09-12-2020, 11:31 AM
Top Jimmy's Avatar
Originally Posted by jrs320 View Post
I migrated my data...
That says it all.
Boot up your old Mac and move the Waves licenses back to the cloud.
Reformat the boot drive in the new Mac and do a fresh Mac OS install. Then do fresh installs of everything you want on it. If you have documents and files on the old Mac that you want on the new Mac, copy them over via thumb drive.
*Edit: DOH! Darryl beat me to it.
James Cadwallader
Old 09-12-2020, 12:58 PM
Default Re: New Mac Pro Doesn't See Avid Omni HD Native Thunderbolt
Yes, I got lazy and used the migration assistant! I should have known better.
I will reformat, wipe, and start from scratch.
Thank you both for your wisdom and advice.
Best,
Jon
Old 09-12-2020, 01:52 PM
Marsdy Marsdy is offline
Best,
Jon
Idealy yes do a clean install . However, I would try reinstalling pro Tools and the HD driver first and make sure your Digilink licence is working.
Dave Marsden
UK
Old 09-12-2020, 05:23 PM
Southsidemusic's Avatar
You need a digilink license on your ilok key and it is a $299 cost and also have you done the settings for audio as you need to do a few clicks in Mojave and upwards for the audio interface and audio apps.
https://support.apple.com/en-us/HT209175
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-13-2020, 08:07 AM
Hi Everyone. I just wanted to express my deep gratitude for your help. Yesterday I wiped the computer and started again. Pro Tools is now up and running and my MC Mix is working. I'll tackle the plugins next.
You were all right and so helpful. Many, many thanks!!!
Old 03-03-2021, 11:59 AM
Matt Stephanson Matt Stephanson is offline
Old-ish thread, but a relevant problem for me today.
I've got 2 HDN OMNI systems and both of them will not work with the 2019 MacPro.
I have:
  • DigiKey licenses on the iLoks and they ARE ACTIVE.
    A fresh OS install of MacOs 10.15.7
    A fresh install of PT 20.12.0.190
    A fresh install of the latest HD Driver from my Master Account (downloaded today - March 3, 2021)
Apple System Profiler sees the HD Native Thunderbolt as "connected" to Thunderbolt Bus 2.
Audio Midi setup does NOT see the HDN.
Pro Tools Ultimate does NOT see the HDN.
Mac Specs: Mac Pro 2019, 3.2 GHz 16 core, 192 GB Ram, Pro Vega II 32 GB
Using an apple USB-C to TB adaptor with the Avid issued TB cable that came with the HD Native box.
I've tried uninstalling and re-installing Pro Tools AND the HD Driver, but still no luck.
I have granted Pro Tools access to the microphone in the security/privacy pane.
Anyone have any ideas?
Many thanks,
Old 03-03-2021, 01:51 PM
DetroitT's Avatar
DetroitT DetroitT is offline
TB3 to TB2 Apple adaptor
apple USB-C to TB adaptor I imagine is the issue.
However if the adaptor is tb3-2 try launching Pro Tools Ultimate holding “n”
To set playback engine.
Old 03-04-2021, 09:39 AM
Thanks for helping out, folks!
1. Is there a known issue with an Apple TB3(usb-c) to TB2 adaptor? If so, what are you using instead?
2. I saw no such security alert pop up during install (done it thrice now).
That must be the issue.
I'll check with our IT dept to see if they have some script preventing this key from loading.
Although, I've manually given the driver and all things Avid full Disc Access, Folder Access, Control, and Input, so that should have enable it, correct?
Obviously not.
This is happening on two systems both identical.
Thanks for the suggestions, folks.
Old 03-04-2021, 11:37 AM
Well, actually Darryl, this is what I was responding to:
I’ve tried everything you suggested, and repeatedly to no success.
Like I did say in my last post, no pop up message ever appeared.
I continue to suspect that it’s our IT dept script preventing this from surfacing, and that it’s not an Avid driver issue.
fs Thunderbolt HD native + Omni, PRE agradl Buy & Sell 2 05-06-2020 06:10 AM
Avid HD Omni & HD Native Thunderbolt edwinstar Buy & Sell 3 10-30-2017 05:28 PM
SELLING AVID C|24 omni thunderbolt hd native greenplanet3d Pro Tools HDX & HD Native Systems (Mac) 0 03-24-2016 10:35 AM
Audio Midi Setup doesn't recognize io on Avid HD Omni Thunderbolt MJarzabek Pro Tools HDX & HD Native Systems (Mac) 5 10-10-2013 07:36 AM
Avid HD Native Thunderbolt and OMNI for Sale drogan88 Buy & Sell 0 03-15-2013 06:47 AM
