Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-11-2009, 12:38 AM
Richard901 Richard901 is offline
Default PT Pref and Database Helper - OK with 8.0?
I've seen many recommendations for Jean-Charles Deshaies' Pref and Database Helper to trash preference files, etc.
Version 2.2 - adds support for Leopard.
Version 2.1 - adds support for PT7.4.
There is no mention of support for PT8.0.
Are people using it successfully with PT8.0? Any problems?
Thanks for your help.
Richard
Pro Tools 2023.9
Ventura 13.6
Old 06-11-2009, 05:20 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT Pref and Database Helper - OK with 8.0?
Richard
Its working fine with 8! i'm on intel 8-core harpertown.
I also use the hardware settings backup app which is a life saver.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-11-2009, 08:41 AM
docbop docbop is offline
As much I would hate to see Jean-Charles Deshaies lose income shouldn't Digi be adding similar functionality to PT. Something kind like like the "Last Known Good" in Windows that saves last registry settings. Have PT save a snapshot of preferences after startup and running. Then have a key combo for to hold during PT startup to say I want to start with a saved preferences file, or option to ignore the zero out the preferences. Then inside running PT and tools to take a snapshot of preference for later use.
Look at how many posts from DigiSupport to users to wipe the all the config files and restart. A tool to do this should be a utility that ships with PT. Maybe Digi could buy out or license Jean-Charles Deshaies tools and ship it.
Digi if you have PT Wishlist please add this to it.
Steve B.
If you think you can or if you think you can't, you're right.
Old 06-11-2009, 11:08 AM
Thanks very much for your help.
Excellent idea, docbop. Perhaps you could start you own thread on this. I'm sure you'd get a lot of support. At the moment, many people may never see your idea, because they will not have read this thread.
Thanks again.
Richard
Pro Tools 2023.9
Ventura 13.6
Preference and Database Helper PT-10 rickymix macOS 9 10-26-2013 10:20 PM
Protools pref and database helper buckccs macOS 1 01-30-2011 01:00 PM
I need beta tester for ProTools Pref and Database Helper JC925602 Pro Tools M-Powered (Mac) 0 06-22-2009 01:04 PM
I need beta tester for ProTools Pref and Database Helper JC925602 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-22-2009 01:03 PM
I need beta tester for ProTools Pref and Database Helper JC925602 Pro Tools TDM Systems (Mac) 0 06-22-2009 11:04 AM
