Old 01-06-2009, 02:48 PM
DigiTechSupt's Avatar
Default Re: auto-tune evo not showing up in plug-ins list
When you install the plug-in, where is it being installed to, exactly?
Avid Audio Tech Support
Support FAQ
Old 01-06-2009, 04:38 PM
agyoung agyoung is offline
Mine shows up in c:\program files\Antares Audio Technologies\Auto Tune Evo RTAS
It also shows up in c:\program files\common files\Digidesign\DAE\plug ins
Old 01-08-2009, 10:33 AM
the-hut the-hut is offline
yes same for me. pro tools recognizes it at startup, i see it load with my other plug ins. it's just not in the list.
Old 01-09-2009, 02:17 AM
billhartung billhartung is offline
Same here too. It shows in my common file/digi/dae/plugins folder on C drive. I then pull copies into the digidesign/dae/plugins folder on my D drive which is my Protools drive. It shows loading up with the other plugins as well at Protoools start up but can't be found anywhere while working in Protools itself. And by the way, Antares is completely dropping the ball as far as support goes. I've emailed them 4 times since their one and only reply and I get nothing. They are obviously ignoring the fact that we paid money for their software and have gotten ripped off! I will not buy another Antares product again.
Old 01-09-2009, 12:01 PM
Hmm. I'm at a loss. If you've tried trashing preferences and that didn't work, I don't know what else could be causing the problem, since the plug-in seems to be installed to the correct directory.
Hopefully Antares will get back to you with an answer. I'll see if I can find a system around here that has that plug-in installed and try to determine what could be going wrong...
Support FAQ
  #16
Old 01-09-2009, 12:09 PM
spkguitar's Avatar
Well, first of all, Pro Tools should not be installed on your "D" drive. Pro Tools itself, and all the peripherals (plugins, etc) should be installed to your system drive.
When Digidesign recommends a separate drive, they recommend it for your audio sessions, not the program itself.
This may not explain the Antares problem, but it certainly may cause other problems.
  #17
Old 01-10-2009, 06:37 AM
I've been thinking all along thay the problem has been on my end but I, just today, loaded an M-Audio plug-in and it shows up just like it's supposed to. Now, it still may be on my end but it's unique to the Antares software so in my mind it's partially their problem. Does anyone agree?
  #18
Old 01-10-2009, 06:30 PM
flautista's Avatar
flautista flautista is offline
try this
install autotune in C by default, then when finish go to programfiles/DIGIDESIGN/DAE/PLUGINS COPY TWO FILES Auto tune there,and paste in
programfiles/COMMON FILES/DIGIDESIGN/DAE/PLUGINS (SO PASTE THERE)
THEN open protools and go to Audiosuite in the menu and look for do the same whith others plugins
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
  #19
Old 01-22-2009, 10:14 AM
anybody have any updates?
  #20
Old 01-22-2009, 10:32 AM
sbag sbag is offline
You can group the plug ins by manufacturer in the insert window and antares doesn't show up at all.
try looking under digidesisn < as the manufacturer
thats where mines is >
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
my efx2 auto tune isnt showing up in pro tools 11 maxidud999 Pro Tools 11 2 07-26-2013 10:59 PM
Is auto tune a free plug in with pro tools 8? lyricalico Pro Tools M-Powered (Win) 2 07-25-2011 03:33 PM
Antares Auto Tune 5 Plug-In RichrdC Pro Tools M-Powered (Win) 4 07-23-2007 06:08 PM
Best Auto Tune Plug-in TBF Entertainment Pro Tools M-Powered (Win) 2 07-31-2006 08:48 AM
Auto Tune not showing up in PT 6.1.1 stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-07-2004 10:20 AM
