Old 02-06-2014, 03:05 PM
jlg75 jlg75 is offline
Default Can't ReAmp in Eleven Rack (output inactive)
I finally decided to try the basic re amping on Eleven Rack using only the eleven rack, no microphones, and I got stuck with this problem: (Image)
For some reason I can´t make the output on the clean signal track to be active. It is displayed in dark grey and when I try to activate it the following message appears "The output could not be made active because its mapped output is currently inactive".
I have gone through the manual and through several videos and instructions online and non of them seem to contemplate this.
Thanks in advance for your help,
File Type: jpg Screen Shot 2014-02-06 at 4.47.10 PM.jpg (82.3 KB, 0 views)
Old 02-06-2014, 04:52 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Can't ReAmp in Eleven Rack (output inactive)
Its likely the IO is setup wrong. Default every tab of the IO and try again.
http://www.youtube.com/watch?v=-Rjk5qVFEE8
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-06-2014, 07:47 PM
Thank you Benoni!!
Worked great!
Really excited to learn a lot here from you guys!
Old 02-07-2014, 06:13 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Originally Posted by jlg75 View Post
Thank you Benoni!!
Worked great!
Yeah we call Brian "Mr. Eleven Rack" Be sure to check out his 11R videos, and his presets. Good stuff all.
Welcome, by the way.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 02-07-2014, 09:10 AM
Just subscribed to his YouTube channel.
Thanks!
Eleven Rack Output to Amp dress4riot Eleven Rack 1 03-26-2013 10:59 AM
eleven rack reamp question anth Eleven Rack 2 02-24-2012 08:17 AM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
How to reamp with eleven rack???? TeamContra Eleven Rack 3 09-07-2011 05:22 PM
Eleven Rack Hardware Reamp negative latency AKA Early??? finkbmx Eleven Rack 1 03-01-2011 04:34 AM
