#61
Re: Audio Record or Playback Volume Error Info
Thanks I was having the problem download and install cs4 and it fix the problem.
Man I was scared. |
#62
This problem may have already been addressed but here is what I have and what I am experiencing;
Powerbook G4 w/ OS Tiger 10.4 MBox 2 w/ 6.8.1 Software External Firewire Hard Drive I am attempting to use my External HD as the recording drive while using the Mac HD as the system drive (standard procedure). In the Workspace it is telling me that I cannot set my external HD as an audio recording volume because is not a valid audio volume. What should the system drive be set to in the workspace browser (in the A/V windows)? I've tried setting everything to the way Ive been told to set it, but something isnt lining up. If anyone can offer help, it would be greatly appreciated. |
#63
hi
i just bought the 002 rack i had problems also with the playback....error i solve it thanks to reading the messages of this page. the new thing was newaccess...error... ok i solve it with you again now...i can't get sound out of the headphones output in every new recording i do even if it shows in the screen of my computer that audio is coming in or coming out. it just happens with the new recordings i do since the problem of newaccess error.... the others sessiions there were recorded on the hard drive are ok...i can ply with them...but not in the new ones... please can somebody help me in this new trial? thank you |
#64
i justt tried changing it to "r"...but it tells me that my MAC HD is not an audio record source...where am i going wrong here.
#65
my solution:
[sorry if this was already stated] highlight fiewire drive [1 click] choose "get info" from file menu under "Ownership and Permissions" set all to "Read and Write" make sure you click open "Details" and set "Owner" & "Other" Access to Read & Write too. then you can can go to PTLE > Windows>Workspace> click on the letter in the "A" column and change t to "R" for "Record" g |
#66
hmm, i'm having this same problem on an external driv ei was using two days ago, now it's suddenly not a valid audio volume. what the hell?
http://www.jonathansegel.com Mac Pro 5,1 3.06ghz 64GB RAM Macbook Pro 2.8Ghz 16GB RAM PT 2022.10 UAD-2 Apollo Quad, PCIE and Satellite |
#67
I tried exactly as you stated and I still get the same message. Does anyone else have any ideas? I'll call tech support in the morning. |
#68
I ended up using Pro Tools 7 and was able to change the Mac HD to "R". My problewm is that i want it to be on my external hard drive and that WONT let me change it to "R". Any help?
thank you |
#69
Refer to the first post in this thread.
Rail
#70
I'm having the exact same problem except I'm using OS10.4.4 and PT7sc3 on a Powerbook G4 1.5 and I have new drives. In the Workspace window, all drives shows "T" and will not allow me to change them to P or R. The drives are formatted at extended nonjournaled. I can start from scratch and have several times but having the same problem. By the way, this unit is using an MBox. My G5/002 combo is working fine but this one.............
Please help. |
workspace - audio record volume | juicytunes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-17-2010 03:33 PM |
"Session must be on an Audio record volume" - Workspace info | jojo101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-19-2007 05:07 PM |
"Session must be on an Audio Record volume" - Workspace info | DigiTechSupt | Pro Tools M-Powered (Mac) | 20 | 03-11-2007 06:23 PM |
Audio Record or Playback Volume Error Info | jarno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-12-2006 05:22 PM |
need help :workspace audio record volume | nicolas paris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-24-2004 05:51 PM |
