Performance and cross-talk problems
First Problem: I recently recorded a three piece band using my Digi001 running PTLE. I ended up with reference vocals bleeding on to every instrument track. Is there any way to avoid this in the future? Second Problem: I'm running two hard drives, but performance is still bad and even after I set the buffers to their highest setting, the session shuts down after adjusting a few of the effects. Is there any recommendations for external drives, and if so, can I retro-fit my tracks to those drives if I add them on? How do I do that? Currently PT is the only thing running on my PC (733mhz)
Re: Performance and cross-talk problems
Do you mean electronic crosstalk or acoustic bleed...
I'm under the impression that you mean acoustic bleed, in which case you'll either need a quieter singer or some means of isolating him from the rest of the group...like an iso booth or letting him do his scratch vox from inside the control room while the rest of the guys are elsewhere in the studio.
Cavell Studios |
Thanks for the input. Actually, everyone went direct except for the vocalist. The drums were Roland V-drums divided over 4 tracks, and each of the four tracks have ghost vocals. I've been able to EQ most of it out by copy/pasting the drum tracks and isolating snare, hihat, ride, etc on separate tracks, but it's still present to some extent. Bass was direct-boxed into the console, and a reference track for guitar was done using a Line 6 POD direct.
Did you have a prefader send on the old vocal track or something...under normal conditions this is the only thing I can think of that may have led to a "ghost" as you call it.
Cavell Studios |
Mmmmm...PC at 733 mhz. PIII/ Celeron? Whatever, that could be your first problem as far as performance is concerned right there.
Cheers,
with regard to crosstalk, are you using a console or is everything plugged directly into the 001?
if you are using a console, i'd suggest it could possibly be a wiring/patching fault or a fault with the console. |
Cross Talk problem | psychothermia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-30-2012 09:00 PM |
Cross-Talk | psychothermia | Pro Tools 10 | 0 | 12-29-2012 12:19 PM |
Can Protools have Track cross talk? | aftermid | Pro Tools TDM Systems (Win) | 4 | 12-17-2008 08:56 PM |
Track cross talk in PT LE 6.4 | wyldout | Tips & Tricks | 3 | 08-18-2004 08:39 PM |
TRACK CROSS TALK ON PT LE 6.4 | wyldout | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-17-2004 09:49 AM |
