Old 09-11-2003, 03:35 PM
theboat theboat is offline
Default Pro Tools controlling Studer 827
Hello,
I've got a session coming up that wants to run a Studer 827 and a PT HD3 system with Sync I/O together. The engineer wants Pro Tools to be the master. We are renting the Studer, we normally just have pro tools. We do not have a lynx or anything-- just wondering if this is possible and if it is how it is done.
Thank You,
Danny
Old 09-11-2003, 03:55 PM
Sean Halley Sean Halley is offline
Default Re: Pro Tools controlling Studer 827
It's common practice in many places to have the slowest device (the 827 in this case) be the master - less perceived lockup time.
With no Lynx, you might be forced to print LTC on track 24 of the 827, and have PT chase it by feeding the output of track 24 to the LTC Input of the Sync I/O.
Hope that helps,
S..
"it's not about making the changes, it's about playing ideas in time"
Scofield...
Old 09-11-2003, 04:01 PM
Sean,
Thanks for your response. Yes, we have actually done that before (PT chase tape). That is probably best. But do you know if the other way (PT chases tape) is even possible without a synchronizer? That is what the enginner is requesting.
Thanks,
Danny
Old 09-11-2003, 04:12 PM
Shawn Simpson Shawn Simpson is offline
I'm not 100% sure, but I'm "pretty sure" that the D827 has a built-in synchronizer. So yes, it should be possible to feed LTC from the Sync I/O and have the Studer chase it. You might also look into using the machine control option. Good luck!!
Old 09-11-2003, 08:15 PM
Rail Jon Rogut Rail Jon Rogut is offline
For any 2" to chase Pro Tools will require a pair of Lynx modules... and probably a video black burst generator.. unless the engineer has his own video source.. but make sure that you terminate the video ref on the Lynx.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-11-2003, 10:04 PM
Nexxt Nexxt is offline
Danny, I could probably be persauded to part with an Adams/Smith ZetaIII synchronizer. Pretty sure it has the lastest software version.
When it's perfect, there'll always be another change!
Controlling Pro Tools Faders 9-24 Philly MIDI 1 08-03-2009 09:43 PM
Pro Tools and Studer A827? kb420 Tips & Tricks 49 12-30-2006 04:59 PM
Pro Tools Sync with Studer? Sick Studios Pro Tools TDM Systems (Mac) 3 04-25-2005 12:28 AM
Controlling another PRO TOOLS Daniel Sasso Pro Tools TDM Systems (Mac) 1 05-17-2004 11:37 AM
Controlling pro tools from another mac using ethernet year3765 General Discussion 7 04-09-2001 04:12 AM
