i913900k Users
Hi guys,
I just upgraded my system to i913900k 64Gb DDR5 5600. I had problems when I first set it up because I was using my old Windows installation, but a suggestion from ejinbc motivated me to do a fresh install of everything. I'd overclocked to 57GHz, but I stepped down to 56GHz all-core, and the system is running well. Apart from standard optimizations that have always been a part of my setup, I'd like to find out how other i913900 users are tweaking their systems for optimum results. 1. How far have you overclocked your systems? 2. What are your settings in regard to hyperthreading? 3. Are you using processor affinity switching or is it unnecessary? What are your settings if you are? 4. Any other useful tweaks? Thanks in advance, guys.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Re: i913900k Users
Assume you meant 5.7 and 5.6MHz? Congrats on the new build, and I would always load OS fresh for anything that involves a new CPU or motherboard.
Re: i913900k Users
I'm using a 13900KF here which is just running at whatever the default motherboard settings are.
Curious to know what you are using to cool your CPU? On heavier tasks, mine definitely seems to be hitting some thermal throttling at 102c. Lots of power, but she runs hot!
Pro Tools Ultimate 2022.12. OSX 13.2. Win 10. HDN. DAD DX-32R. DADman 5.3.4.2. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Sync HD. Dolby Mastering Suite 3.7.2 via RME HDSPe MADI. |
Re: i913900k Users
Sorry, I did mean 5.7 and 5.6GHz. I'd had a bit too much to drink when I posted that You are right about fresh OSs for new hardware. I'd done what I did several times in the past without issues, but most of my weird problems disappeared when I did a fresh install of everything. Never too late for an old dog to learn new tricks
Re: i913900k Users
At 5.6 all-core, the highest temps I've seen for heavy loads are 80c. Maybe that has something to do with the Thermal Grizzly Conductonaut that I use. I'm usually around 40-60. Did I win the lottery this time? At 5.7GHz the system didn't throttle, but I saw some instability. V-core is currently 1.35v.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins Last edited by lesbrunn; 02-18-2023 at 02:11 AM. |
Re: i913900k Users
1. I run all cores at a constant 5.1GHz, with no up/down throttling. As I recall, my i9 can run at 5.3 max boost, but I am playing it safe/conservative. It's steady, stable, and crazy powerful. 2. I leave hyperthreading on. 3. Lately, I haven't seen any Pro Tools CPU spiking, so I haven't been adjusting affinity. Perhaps the latest Win 11 updates are handling things better? Not sure... (The last time I did see spikes was quite awhile ago. I just un-checked cores 0 & 1, and that fixed the spikes right away.) 4. Go through Windows Settings and basically turn everything off. Do a Google search and/or YouTube search for "gaming" optimizations for ideas. Kill unnecessary startup items and kill unnecessary Windows Services. Uninstall bloatware. Even a clean Windows install has some bloatware. Run a spyware scan. CCleaner reg clean and regular cleaning too. But basically if you ALWAYS keep Windows/all plugs/audio interface drivers FULLY up-to-date, you'll be golden. Your CPU has a ton of "headroom", so even doing nothing more than the standard AVID optimizations will give you a great Pro Tools rig. Oh yeah, take boot drive images. I'm using Macrium Reflect free version. Congrats on the build!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume Last edited by EGS; 02-20-2023 at 05:57 AM. Reason: typo |
Re: i913900k Users
Nice! I'm just running an air cooler here... and not a particularly flash one at that. How loud is that water loop? I've been contemplating putting a custom loop in mine, but a large part of me also can't be bothered dealing with water + computer components.
Re: i913900k Users
I wouldn't go for a custom loop myself but I believe there are quieter AIO offerings out there from Corsair and others. Just more expensive.
Re: i913900k Users
I feel the same way you do about processor affinity. I used to have Process Lasso do that for me automatically, but I've turned it off now. My reasoning is that with Intel's new CPU architecture, the e-cores should be able to take care of all the background stuff and allow the p-cores to do their thing. In all my past builds hyper-threading has been my friend.
Re: i913900k Users
So far it's running smoothly, and I have still not seen temps above 80c. Between 40 and 60c on average when running a moderately heavy PT session (buffer 128). Maybe you should look at your cooling and thermal paste. I use Thermal Grizzly Conductonaut.
Are Windows users seeing the same bugs as Mac users? | poly915 | Pro Tools TDM Systems (Win) | 2 | 08-13-2007 10:08 PM |
Are Windows users seeing the same bugs as Mac users? | poly915 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-11-2007 07:51 PM |
To The PowerBook users (and also WAVES users) | ·[-_-]· Richon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-05-2005 06:42 AM |
vst2retas users inhere? non-users, read this to ! | ikke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-09-2004 03:41 PM |
Need users opinion: New digi users domain name (unofficial).. | David Fisher | General Discussion | 2 | 07-30-2002 09:27 PM |
