Re: Xpand Freezing PT
Dot, your system specs seems fine to me anyway but if you have one out of date plug-in it will throw your whole system. Xpand!2 doesn't freeze for me but if I'm auditioning whilst playing back Pro Tools does stop playback.
Aaron Mulqueen - 001 HD Native |
filosofem and DOT.
I don't generally have problems with my setup other than the odd XPAND2 crashing the system. It seems to be related to changing patches while either I'm in playback mode or if I'm simply just playing on the keyboard and auditioning sounds. It takes a while for it to happen so I can't say it's one patch or another. It just seems to be related to a patch change. I can live with it because "knock on wood" I've not lost any of my work. I can save and restart and plus I really like XPAND2 a lot. I mentioned this to DOT just in case DOT was also doing the same thing. Perhaps we can pinpoint the cause if we're using similar workflows. (don't want to hijack his post) DOT, I noticed you have a network printed installed. Do you have any background programs running that talk to the printer? I did and that caused me a lot of problems in the past so I removed it. Also, you've got a wireless card. I've read posts where wireless can cause problems. Too bad windows 7 makes it so hard to manage hardware. To reproduce the problem on my system I do one of the following 1) - have an XPAND2 instance open with a patch selected. - select the track so that you can play XPAND2 from the midi controller - hit play on the transport ( or in my case - Command 8) - advance through the patches each for about a second or two. - at some random point in time, no more sound from the system - system becomes unstable so quickly save and exit or just exit. 2) - have an XPAND2 instance open with a patch selected. - select the track so that you can play XPAND2 from the midi controller - play something on the midi controller - don't hit play - advance through the patches each for about a second or two or use auto patch advance feature in XPAND2 - at some random point in time, no more sound from the system - system becomes unstable so quickly save and exit or just exit. Seems to be stable until I start to change patches. Here's my system - Note - I have RAID installed on this box but always disabled when using PT9.01. I have also resisted 9.02 due to stories about problems with grid lines disappearing. "G" drive 10K RPM VelociRaptor is audio/music drive. SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : Alain-PC User : Alain Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 3.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus P6T DELUXE V2 BIOS : AMI 1108 09/21/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 3.42GHz (6.84GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 3.42GHz (6.84GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 760MHz (1.52GHz) Memory Module(s) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce GTX 470 (448 SM5.0 1.22GHz, 1.3GB, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 470 (448 SM5.0 1.22GHz, 1.3GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz, 1.3GB) OpenCL Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 512MB DDR3 2x900MHz) Compute Shader Processor : NVIDIA GeForce GTX 470 (448SP 1.22GHz, 1.3GB) Compute Shader Processor : NVIDIA GeForce 9800 GT (112SP 1.4GHz, 512MB DDR3 2x900MHz) CUDA Processor : NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz, 1.3GB) CUDA Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 512MB DDR3 2x900MHz) Storage Devices Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) : 1TB (H:) Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) : 1TB (I:) Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ) : 2TB (C:) (D:) (E:) (F:) Seagate ST31000333AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (Q:) WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) : 279GB (G:) Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ) : 466GB (K:) Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ) : 466GB (L:) Generic STORAGE DEVICE (USB) : N/A (U:) Generic STORAGE DEVICE (USB) : N/A (V:) Generic STORAGE DEVICE (USB) : N/A (W:) Generic STORAGE DEVICE (USB) : N/A (X:) ATAPI iHBS212 2 (SATA150, BD-RW, DVD+-RW, CD-RW, 8MB Cache) : N/A (M:) HL-DT-STDVDRAM GE20LU10 (USB) : N/A (Z:) Logical Storage Devices 03_Video (H:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) 04_IMAGES (I:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) 00_XBoot (D:) : 100GB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ) 05_Dock (Q:) : 932GB (NTFS) @ Seagate ST31000333AS (1TB, SATA300, 3.5", 7200rpm, NCQ) 02_Music (G:) : 279GB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) 00_Data (E:) : 101GB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ) 00_Vid (F:) : 1TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ) 06_Photos (K:) : 466GB (NTFS) @ Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ) 07_Spare2 (L:) : 466GB (NTFS) @ Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ) 00_Boot (C:) : 300GB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ) Removable Drive (U:) : N/A @ Generic STORAGE DEVICE (USB) Removable Drive (V:) : N/A @ Generic STORAGE DEVICE (USB) Removable Drive (W:) : N/A @ Generic STORAGE DEVICE (USB) Removable Drive (X:) : N/A @ Generic STORAGE DEVICE (USB) Optical Drive (M:) : N/A @ ATAPI iHBS212 2 (SATA150, BD-RW, DVD+-RW, CD-RW, 8MB Cache) Optical Drive (Z:) : N/A @ HL-DT-STDVDRAM GE20LU10 (USB) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Device : EVGA GF100 High Definition Audio Controller Audio Codec : nVidia Mutara V08 [NV2] Audio Codec : 1 0001h Audio Codec : 1 0001h Disk Controller : ASUS 6 port SATA AHCI Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Brother QL-570 (300x600, USB) Printer : Brother HL-2070N series (1200x1200) Printer : Adobe PDF Converter (4000x4000, Colour) Scanners and Cameras Scanner : EPSON Perfection 2480/2580 (Scanner, 2400x2400, USB) Peripherals Media Player : () Media Player : () Media Player : () Media Player : () Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 100Mbps) Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Alain, I can not reproduce this issue. It is more than likely that this issue is pointing more towards your system. Maybe not in hardware respects, cause your rig is the same if not better than mine and current. Ummm... can you post a sandra report of your plug-ins please?
just ran 3 hour session using xpand2, was changing patches, sequencing and doung pretty much all... and no issue at all. It worked perfectly fine today I'm really not sure what could be the reason for "crash" last week it was happening too often, but now i can't complain at all (at least today)
www.dominicdotokune.com |
DOT - same here tonight. No crashing and I really tried to push the system to the limit too. At one point had RTAS usage up to 45% with a dozen VIs.
filosofem, I managed to get the tech support utility to cough up the version numbers for the plug-ins - not easy to do in PT9. I couldn't find a copy of "trasher" to download - by some accounts it seems to be able to report version numbers. I'm not sure what I'm looking for as it's really hard to find out what the latest version should be for the plugins from some manufactures. Some appear to report back incorrectly - ie. Addictive Drums - I know it's V1.5.2. Line 6 - who knows? Plug-In Version List started: Tue May 24 22-46-32 2011 Plug-In: Version: C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\ .. Not Available Addictive Drums.dpm ----------------1.5.1.23 Addictive Drums.dpm.rsr ------------Not Available AIRChorus.dpm ----------------------1.0.2.10105 AIRChorus.dpm.rsr ------------------Not Available AIRDistortion.dpm ------------------1.0.2.10105 AIRDistortion.dpm.rsr --------------Not Available AIRDynamicDelay.dpm ----------------1.0.2.10105 AIRDynamicDelay.dpm.rsr ------------Not Available AIREnhancer.dpm --------------------1.0.2.10105 AIREnhancer.dpm.rsr ----------------Not Available AIREnsemble.dpm --------------------1.0.2.10105 AIREnsemble.dpm.rsr ----------------Not Available AIRFilterGate.dpm ------------------1.0.2.10105 AIRFilterGate.dpm.rsr --------------Not Available AIRFlanger.dpm ---------------------1.0.2.10105 AIRFlanger.dpm.rsr -----------------Not Available AIRFrequencyShifter.dpm ------------1.0.2.10105 AIRFrequencyShifter.dpm.rsr --------Not Available AIRFuzz-Wah.dpm --------------------1.0.2.10105 AIRFuzz-Wah.dpm.rsr ----------------Not Available AIRKillEQ.dpm ----------------------1.0.2.10105 AIRKillEQ.dpm.rsr ------------------Not Available AIRLo-Fi.dpm -----------------------1.0.2.10105 AIRLo-Fi.dpm.rsr -------------------Not Available AIRMulti-Chorus.dpm ----------------1.0.2.10105 AIRMulti-Chorus.dpm.rsr ------------Not Available AIRMulti-Delay.dpm -----------------1.0.2.10105 AIRMulti-Delay.dpm.rsr -------------Not Available AIRNon-LinearReverb.dpm ------------1.0.2.10105 AIRNon-LinearReverb.dpm.rsr --------Not Available AIRPhaser.dpm ----------------------1.0.2.10105 AIRPhaser.dpm.rsr ------------------Not Available AIRReverb.dpm ----------------------1.0.2.10105 AIRReverb.dpm.rsr ------------------Not Available AIRSpringReverb.dpm ----------------1.0.2.10105 AIRSpringReverb.dpm.rsr ------------Not Available AIRStereoWidth.dpm -----------------1.0.2.10105 AIRStereoWidth.dpm.rsr -------------Not Available AIRTalkbox.dpm ---------------------1.0.2.10105 AIRTalkbox.dpm.rsr -----------------Not Available AIRVintageFilter.dpm ---------------1.0.2.10105 AIRVintageFilter.dpm.rsr -----------Not Available ARIA Player RTAS_x86.dpm -----------8.0.4.1 BF Essential Clip Remover.dpm ------8.0.0.314 BF Essential Clip Remover.dpm.rsr --Not Available BF Essential Correlation.dpm -------8.0.0.314 BF Essential Correlation.dpm.rsr ---Not Available BF Essential Meter Bridge.dpm ------8.0.0.314 BF Essential Meter Bridge.dpm.rsr --Not Available BF Essential Noise Meter.dpm -------8.0.0.314 BF Essential Noise Meter.dpm.rsr ---Not Available BitterSweetII.dpm ------------------2.2.0.7094 BitterSweetII.dpm.rsr --------------Not Available bombfactory BF76.dpm ---------------8.0.0.314 bombfactory BF76.dpm.rsr -----------Not Available Boom.dpm ---------------------------1.0.2.10105 Boom.dpm.rsr -----------------------Not Available Chorus.dpm -------------------------8.0.0.314 Chorus.dpm.rsr ---------------------Not Available Click.dpm --------------------------8.0.0.314 Click.dpm.rsr ----------------------Not Available D-Verb.dpm -------------------------8.0.0.314 D-Verb.dpm.rsr ---------------------Not Available DB-33.dpm --------------------------1.0.2.10105 DB-33.dpm.rsr ----------------------Not Available DigiReWire.dpm ---------------------9.0.1.41 DigiReWire.dpm.rsr -----------------Not Available Dither.dpm -------------------------8.0.0.314 Dither.dpm.rsr ---------------------Not Available Dynamics III.dpm -------------------8.0.0.314 Dynamics III.dpm.rsr ---------------Not Available Elastic Audio.dpm ------------------9.0.1.41 Elastic Audio.dpm.rsr --------------Not Available Eleven Delay UI.dpm ----------------Not Available Eleven Delay UI.dpm.rsr ------------Not Available Eleven Distortion UI.dpm -----------Not Available Eleven Distortion UI.dpm.rsr -------Not Available Eleven Dynamics UI.dpm -------------Not Available Eleven Dynamics UI.dpm.rsr ---------Not Available Eleven EQ UI.dpm -------------------Not Available Eleven EQ UI.dpm.rsr ---------------Not Available Eleven Free.dpm --------------------8.0.0.314 Eleven Free.dpm.rsr ----------------Not Available Eleven FX Loop UI.dpm --------------Not Available Eleven FX Loop UI.dpm.rsr ----------Not Available Eleven Modulation UI.dpm -----------Not Available Eleven Modulation UI.dpm.rsr -------Not Available Eleven Reverb UI.dpm ---------------Not Available Eleven Reverb UI.dpm.rsr -----------Not Available Eleven Tuner UI.dpm ----------------Not Available Eleven Tuner UI.dpm.rsr ------------Not Available Eleven UI.dpm ----------------------8.0.4.994 Eleven UI.dpm.rsr ------------------Not Available Eleven Volume UI.dpm ---------------Not Available Eleven Volume UI.dpm.rsr -----------Not Available Eleven Wah UI.dpm ------------------Not Available Eleven Wah UI.dpm.rsr --------------Not Available EQ III.dpm -------------------------8.0.0.314 EQ III.dpm.rsr ---------------------Not Available Flanger.dpm ------------------------8.0.0.314 Flanger.dpm.rsr --------------------Not Available Hybrid -----------------------------Not Available Hybrid.dpm -------------------------1.6.0.9474 Hybrid.dpm.rsr ---------------------Not Available Invert-Duplicate.dpm ---------------8.0.0.314 Invert-Duplicate.dpm.rsr -----------Not Available iZotope_Radius_Win32.dll -----------1.0.0.439 Kontakt 4.dpm ----------------------4.2.3.4914 Line 6 -----------------------------Not Available LoFi.dpm ---------------------------8.0.0.314 LoFi.dpm.rsr -----------------------Not Available Maxim.dpm --------------------------8.0.0.314 Maxim.dpm.rsr ----------------------Not Available Melodyne.dpm -----------------------1.2.1.12 Melodyne.dpm.rsr -------------------Not Available MiniGrand.dpm ----------------------1.0.2.10105 MiniGrand.dpm.rsr ------------------Not Available Mod Delay II.dpm -------------------8.0.0.314 Mod Delay II.dpm.rsr ---------------Not Available Multi-Tap Delay.dpm ----------------8.0.0.314 Multi-Tap Delay.dpm.rsr ------------Not Available Normalize-Gain Change.dpm ----------8.0.0.314 Normalize-Gain Change.dpm.rsr ------Not Available Philharmonik.dpm -------------------0.0.0.0 Philharmonik.dpm.rsr ---------------Not Available Philharmonik.ini -------------------Not Available Ping-Pong Delay.dpm ----------------8.0.0.314 Ping-Pong Delay.dpm.rsr ------------Not Available Pitch.dpm --------------------------8.0.0.314 Pitch.dpm.rsr ----------------------Not Available RectiFi.dpm ------------------------8.0.0.314 RectiFi.dpm.rsr --------------------Not Available Reverse-DC Removal.dpm -------------8.0.0.314 Reverse-DC Removal.dpm.rsr ---------Not Available SansAmp PSA-1.dpm ------------------8.0.0.314 SansAmp PSA-1.dpm.rsr --------------Not Available SciFi.dpm --------------------------8.0.0.314 SciFi.dpm.rsr ----------------------Not Available Signal Generator.dpm ---------------8.0.0.314 Signal Generator.dpm.rsr -----------Not Available SignalTools.dpm --------------------8.0.0.314 SignalTools.dpm.rsr ----------------Not Available Structure.dpm ----------------------1.0.5.10611 Structure.dpm.rsr ------------------Not Available STTool.dpm -------------------------2.2.0.7094 STTool.dpm.rsr ---------------------Not Available Surround Mixer.dpm -----------------9.0.1.41 Surround Mixer.dpm.rsr -------------Not Available Time Comp-Exp-Pitch Shift.dpm ------8.0.0.314 Time Comp-Exp-Pitch Shift.dpm.rsr --Not Available Time Shift.dpm ---------------------8.0.1.510 Time Shift.dpm.rsr -----------------Not Available TimeAdjuster.dpm -------------------8.0.0.314 TimeAdjuster.dpm.rsr ---------------Not Available TL AutoPan.dpm ---------------------8.0.0.314 TL AutoPan.dpm.rsr -----------------Not Available TL InTune.dpm ----------------------8.0.0.314 TL InTune.dpm.rsr ------------------Not Available TL Master Meter.dpm ----------------8.0.0.314 TL Master Meter.dpm.rsr ------------Not Available TL Metro.dpm -----------------------8.0.0.314 TL Metro.dpm.rsr -------------------Not Available Trim.dpm ---------------------------8.0.0.314 Trim.dpm.rsr -----------------------Not Available Vacuum.dpm -------------------------1.0.2.10105 Vacuum.dpm.rsr ---------------------Not Available VariFi.dpm -------------------------8.0.0.314 VariFi.dpm.rsr ---------------------Not Available Xpand!.dpm -------------------------2.0.2.10105 Xpand!.dpm.rsr ---------------------Not Available End Directory: C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\ .. Not Available BF Essential Tuner.dpm -------------8.0.0.314 BF Essential Tuner.dpm.rsr ---------Not Available Dynamics II.dpm --------------------8.0.0.314 Dynamics II.dpm.rsr ----------------Not Available EQ II.dpm --------------------------8.0.0.314 EQ II.dpm.rsr ----------------------Not Available Funk Logic Mastererizer.dpm --------8.0.0.314 Funk Logic Mastererizer.dpm.rsr ----Not Available Stereo Dithered Mixer.dpm ----------9.0.1.41 Stereo Dithered Mixer.dpm.rsr ------Not Available Stereo Mixer.dpm -------------------9.0.1.41 Stereo Mixer.dpm.rsr ---------------Not Available Surround Dithered Mixer.dpm --------9.0.1.41 Surround Dithered Mixer.dpm.rsr ----Not Available End Directory: C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused) C:\Program Files\Digidesign\Pro Tools\ .. Not Available AAFCOAPI.dll -----------------------1.1.6.6995 AFnd.dll ---------------------------9.0.1.41 asifont.map ------------------------Not Available Asiport.rsr ------------------------Not Available BUI.dll ----------------------------9.0.1.41 BUI_Resource404.dll ----------------9.0.1.41 BUI_Resource411.dll ----------------9.0.1.41 BUI_Resource412.dll ----------------9.0.1.41 BUI_Resource804.dll ----------------9.0.1.41 Cfd.dll ----------------------------9.0.1.41 CFD.idb ----------------------------Not Available CFD.vdb ----------------------------Not Available Cfd_Resource404.dll ----------------9.0.1.41 Cfd_Resource411.dll ----------------9.0.1.41 Cfd_Resource412.dll ----------------9.0.1.41 Cfd_Resource804.dll ----------------9.0.1.41 CFnd.dll ---------------------------9.0.1.41 CFnd_Resource404.dll ---------------9.0.1.41 CFnd_Resource411.dll ---------------9.0.1.41 CFnd_Resource412.dll ---------------9.0.1.41 CFnd_Resource804.dll ---------------9.0.1.41 DAE.dll ----------------------------9.0.1.41 DAE.dll.rsr ------------------------Not Available DAE_Resource404.dll ----------------9.0.1.41 DAE_Resource411.dll ----------------9.0.1.41 DAE_Resource412.dll ----------------9.0.1.41 DAE_Resource804.dll ----------------9.0.1.41 Databases --------------------------Not Available DFW.dll ----------------------------9.0.1.41 DFW.idb ----------------------------Not Available DFW.vdb ----------------------------Not Available DFW_KeyHook.dll --------------------9.0.1.41 DFW_Resource404.dll ----------------9.0.1.41 DFW_Resource411.dll ----------------9.0.1.41 DFW_Resource412.dll ----------------9.0.1.41 DFW_Resource804.dll ----------------9.0.1.41 DHS.dll ----------------------------9.0.1.41 DHS.idb ----------------------------Not Available DHS.vdb ----------------------------Not Available DHS_Resource404.dll ----------------9.0.1.41 DHS_Resource411.dll ----------------9.0.1.41 DHS_Resource412.dll ----------------9.0.1.41 DHS_Resource804.dll ----------------9.0.1.41 DigiExt.dll ------------------------9.0.1.41 DigiMIDI.dll -----------------------9.0.1.41 DigiMIDIServices.dll ---------------9.0.1.41 DigiMIDI_Resource404.dll -----------9.0.1.41 DigiMIDI_Resource411.dll -----------9.0.1.41 DigiMIDI_Resource412.dll -----------9.0.1.41 DigiMIDI_Resource804.dll -----------9.0.1.41 DigiPlatformSupport.dll ------------9.0.1.41 DigiRefClock.dll -------------------9.0.1.41 DigiReg.file -----------------------Not Available digiSPTIService.exe ----------------9.0.1.41 DigiSyncReader.dll -----------------9.0.1.41 DigiVout.qtr -----------------------Not Available DigiVout.qtx -----------------------Not Available DirectIO.dll -----------------------9.0.1.41 DMC.dll ----------------------------9.0.1.41 DSI.dll ----------------------------9.0.1.41 DSPManager.dll ---------------------9.0.1.41 DUI.dll ----------------------------9.0.1.41 DUI.idb ----------------------------Not Available DUI.vdb ----------------------------Not Available DUI_Resource404.dll ----------------9.0.1.41 DUI_Resource411.dll ----------------9.0.1.41 DUI_Resource412.dll ----------------9.0.1.41 DUI_Resource804.dll ----------------9.0.1.41 FFmt.dll ---------------------------9.0.1.41 FFmt_Resource404.dll ---------------9.0.1.41 FFmt_Resource411.dll ---------------9.0.1.41 FFmt_Resource412.dll ---------------9.0.1.41 FFmt_Resource804.dll ---------------9.0.1.41 GDIPlusWrapper.dll -----------------Not Available Grooves ----------------------------Not Available Gtr.dll ----------------------------9.0.1.41 Gtr_Resource404.dll ----------------9.0.1.41 Gtr_Resource411.dll ----------------9.0.1.41 Gtr_Resource412.dll ----------------9.0.1.41 Gtr_Resource804.dll ----------------9.0.1.41 LGC.dll ----------------------------9.0.1.41 MMERefresh.exe ---------------------9.0.1.41 NeoAccess.dll ----------------------9.0.1.41 NTL.dll ----------------------------Not Available OMFToolkit.dll ---------------------9.0.1.41 Plug-Ins.lnk -----------------------Not Available Pro Tools Registration.exe ---------0.1.0.11 Pro Tools Utilities ----------------Not Available ProTools.cat -----------------------Not Available ProTools.digitrace -----------------Not Available ProTools.dll -----------------------9.0.1.41 ProTools.exe -----------------------9.0.1.41 ProTools.idb -----------------------Not Available PROTOOLS.RSR -----------------------Not Available ProTools.vdb -----------------------Not Available ProToolsApp.idb --------------------Not Available ProToolsApp.vdb --------------------Not Available ProToolsApp_Resource404.dll --------9.0.1.41 ProToolsApp_Resource411.dll --------9.0.1.41 ProToolsApp_Resource412.dll --------9.0.1.41 ProToolsApp_Resource804.dll --------9.0.1.41 ProToolsNative_FW_d400.bin ---------Not Available ProToolsNative_FW_d410.bin ---------Not Available ProToolsNative_FW_d411.bin ---------Not Available ProTools_Resource404.dll -----------9.0.1.41 ProTools_Resource411.dll -----------9.0.1.41 ProTools_Resource412.dll -----------9.0.1.41 ProTools_Resource804.dll -----------9.0.1.41 PTHelp -----------------------------Not Available RTEngineDiag.dll -------------------9.0.1.41 Session Templates ------------------Not Available Sib.dll ----------------------------9.0.1.41 Sib_Resource404.dll ----------------Not Available Sib_Resource411.dll ----------------Not Available Sib_Resource412.dll ----------------Not Available Sib_Resource804.dll ----------------Not Available SoftwareUpdater.exe ----------------9.0.1.41 SoftwareUpdater_Resource404.dll ----9.0.1.41 SoftwareUpdater_Resource411.dll ----9.0.1.41 SoftwareUpdater_Resource412.dll ----9.0.1.41 SoftwareUpdater_Resource804.dll ----9.0.1.41 StreamManager.dll ------------------8.0.3.251 SystemLink.dll ---------------------9.0.1.41 TCPE.dll ---------------------------9.0.1.41 Trns.dll ---------------------------Not Available updater-version.properties ---------Not Available VenueLink.dll ----------------------Not Available xerces-c_2_6.dll -------------------2.5.0.0 End Directory: C:\Program Files\Digidesign\Pro Tools C:\Program Files\Digidesign\DAE\ Find Function returned no results for directory: C:\Program Files\Digidesign\DAE\* |
#16
Alain, you know you are going to have to spend the time checking whether those plug-ins are up to date. From the plug-ins that I use they seem to be fine but I don't have all that is on that list.
Currently, I think this is the only thread I know of that contains this issue. Two, maybe three users out of thousands have a problem. It is more than likely it is a user problem based on their system in some form and you'll need to troubleshoot.
Pro Tools 10 freezing, XPand missing [installed on SSD w/ OS] | avryluy | Windows | 2 | 03-01-2014 08:07 AM |
Pro tools SLOW, and Freezing then continuing, then freezing again | DJX-RAY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 07:52 AM |
PT LE 8.04 freezing on loading soft synth (xpand!, hybrid, etc..), after computer upg | microbang | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-30-2010 10:53 AM |
Xpand can't find the Xpand.dat | mountainman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-12-2009 12:24 AM |
Xpand.dat Gone/Xpand Crashes PT 7.4 | dts.music | Virtual Instruments | 2 | 09-16-2008 09:00 PM |
