Old 11-04-2002, 09:55 AM
Chris Scott Chris Scott is offline
Default Importing Plugins to new songs
I have a group I'm recording and i just finished the drums, I have the first song's drums pretty dialed in with th EQ's, Comps, and Gates that will be good for now until mixing comes around...How do I import the settings into the other songs without starting over..Please Need help Dont want to waste to much time doing this transfer....Thanks Chris
Old 11-04-2002, 10:34 AM
J. FO J. FO is offline
Default Re: Importing Plugins to new songs
you could just save the plugin in parameter. open up the plugin box. click the down arrow and hit save as and name it, probably the band's name. past that, i'm not sure how to import plugs in the order you have them with their settings into a new session. this will save a little bit of time at least.
Jeremy Forbis
Old 11-04-2002, 10:42 AM
ptrbas ptrbas is offline
You can also make a template for tracks and plugins you can use each time when you start recording and save your session "save as".
Pieter
Old 11-04-2002, 05:22 PM
oohhh. that would definitely be the way to go. templates, i always forget about them.
Jeremy Forbis
Importing reference songs from cd help... broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-22-2009 09:08 PM
Importing downloaded songs into PT from iTunes lwilliam General Discussion 4 01-30-2008 06:35 PM
Importing Sonar5 songs to use in Pro Tools LE7 Chingas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-30-2006 12:43 AM
Importing CD songs to PTs 6969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-21-2002 10:08 AM
Importing songs from CD BROWNIE Digidesign Hardware & Software 1 03-08-2002 11:45 PM
