Old 09-30-2002, 10:44 AM
Roy Howell Roy Howell is offline
Default MusicMatchJukebox startup sound....help me find and destroy it...
I cannot stand the MMjukebox startup sound anymore. Anyone know where it may be hiding, and if it's deletable?
Thanks, Roy
rh music
Old 09-30-2002, 11:24 AM
Plastik909 Plastik909 is offline
Default Re: MusicMatchJukebox startup sound....help me find and destroy it...
Within Program files on the C: drive, go to the Music Match directory, then Search for a file called mmjbstart.wav, delete this file and you should be sorted.
Old 09-30-2002, 11:49 AM
Plastik909,
I thank you, my family thanks you, and probably my neighbors, too... I hated that sound. It is now less than dust... a mere memory I choose never to recall a-gain... [img]images/icons/grin.gif[/img]
~Roy
rh music
Old 09-30-2002, 11:54 AM
De Nada...
I wasn’t a fan of that either – the file is sitting in my recycle bin too.
Old 09-30-2002, 11:55 AM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Speaking of Music Match (who's open sound I also HATE), has anyone noticed it poens VERY slow with Win XP. It worked just fine with Win ME.
Old 09-30-2002, 01:14 PM
Originally posted by soundsurfr:
Hey, since we're on this topic, maybe you folks can help me. Since I downloaded and installed the new version of Real Player (which I needed for a specific application), MusicMatch won't play anymore.
The strange thing is that the obnoxious startup sound plays fine, then when the MP3 player runs, there's no sound. I have searched high and low for a way to check the output settings or some other means to ensure that the thing is going out to my sound card, but I can't find a way.
Anyone?
<font size="2" face="Verdana, Arial">Real Player wants to dominate. If Real Player was good it’d let you not make it the default media player.
This may not be the only way to do this but ….
If you do a normal install of Real Player it becomes the default player, I tried to no avail to turn this setting off but it kept popping up.
So I uninstalled RP. Set the defaults on my other player (make them the default player). Then re-installed Real Player and did a custom install and selected as little as possible. Now it works okay.
Old 09-30-2002, 01:43 PM
CGlass CGlass is offline
Actually MMJB starts up much faster on XP for me. Go figure.
Casey
Old 09-30-2002, 03:15 PM
SSurfr/Greg,
Plastik909 is exactly right about RealPlayer. I use it and delete it when it's job is done. But, whatever is your choice, you must go in and disable all the 'player options', etc., of the other streamers in your PC. I keep WindowsMediaPlayer(for CD's and Videos) and MMJukebox(for WAV's and MP3 conversion)... Too many streamers is not good, I've found.
One way to tell which one is 'claiming' your WAV's and MP3's is by their icons. If the wrong player icon is on them, it's time to reset the options.
rh music
Old 09-30-2002, 05:08 PM
JamesV JamesV is offline
nuke it in msconfig!!!
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al
Old 09-30-2002, 07:20 PM
soundsurfr soundsurfr is offline
Thanks guys. I'll be nuking Real Player 'til I need it again.
Soundsurfr
MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM
M-Audio Firewire 1814
Yosemite OS
Digi wants to destroy the desk Borne Digidesign Hardware & Software 1 08-09-2013 04:34 PM
Why does file search destroy my machine? IO Composer Pro Tools 10 7 01-14-2012 03:45 PM
no sound on startup Ronnisi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2010 11:48 PM
MBox 2 Pro - No sound on startup Sonny in London 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 04-12-2007 04:14 PM
mac startup ? can't find startup disc peterfitz Pro Tools TDM Systems (Mac) 1 03-24-2000 08:27 AM
