Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 04-09-2015, 03:18 PM
mshaffer mshaffer is offline
Default pro tools 10 hd without hardware
Can you use hd 10 without the hardware and record directly from a sound board to the software on the computer without using the hardware?
Old 04-09-2015, 03:21 PM
Raoul23 Raoul23 is online now
Default Re: pro tools 10 hd without hardware
Yep, without HD hardware it will open up with ASIO4ALL as the play back engine if on PC
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 04-09-2015, 06:30 PM
or Core Audio on a Mac. About the only thing you will miss(by not having HD cards) is the DSP processing for plugins, and latency will be a bit higher(but should not be an issue)
Old 04-18-2015, 10:59 AM
Can it be done without asio4all I have a Allen & Heath qu 32 channel digital sound board that I use a usb b connection to usb on a laptop running reaper for recording software all I need is the qu 32 driver which shows up as an asio qu 32 and I have 32 channels directly out to laptop. Will protools do the same thing and what about Ilok will that be an issue.
Old 04-19-2015, 05:22 AM
This should work fine. Not sure why iLok would be an issue, but you will need the iLok connected all the time Keep in mind that this thread is in the Mac section and most of this thread has been about PC. Maybe a moderator can move to the proper section??
Old 04-19-2015, 07:30 AM
Thanks Albee1952 I appreciate your help and your are correct for now it is pc but it will be for mac down the road.
Using Pro Tools 10 without Hardware The Saint627 Windows 20 04-20-2015 10:44 AM
How do I get Pro Tools 9 to run w/o hardware Ms.Samo Windows 14 04-21-2011 06:35 PM
Anyone Ever Tried To Fly With Their Pro Tools Hardware? SGT PEPPAS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-08-2007 07:25 PM
Wish Pro Tools can be used without Hardware....... hubad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 10-26-2005 11:15 PM
Do you need Pro Tools Hardware to run LE protram 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-19-2002 11:21 PM
