Old 09-24-2011, 04:58 PM
jamiet jamiet is offline
Default connecting a hardware insert
Hello,
I am trying to connect my hardware compressor as an insert on my MBox Pro. I have purchased a TRS insert cable. When I insert the insert 1 in the I/O section of the insert views I get a message saying the insert was made inactive as the output path is in use. I have had a look in the I/O section in the Setup menu but I'm not 100% sure.
Any assistance would be most appreciated.
Jamie
Old 09-25-2011, 06:54 AM
Default Re: connecting a hardware insert
What are the connections on the hardware compressor? If it is separate input and output jacks, you need 2 separate TRS cables(one from a line output of the Mbox and the other to a line input on the Mbox. You also need to go to the IO setup page>insert tab and configure a set of IO to do this. Have you missed one of these details?
Old 09-25-2011, 04:58 PM
DJKeys's Avatar
DJKeys DJKeys is offline
This worked fine for me the first time, Plugged in an insert cable to my compressor (tip=send, ring=receive) and have my mic plugged into Input 1 of the MBox Pro.
I am not sure that the settings on the insert page of the I/O are related to the MBox Pro hardware inserts.
iMAC 3.2GHz 6-core i7
250GB SSD (internal)
1TB SSD (external)
16GB RAM
OSX 10.14.5
PT 2019.6
Waves Gold/RenMaxx v10.1
iZotope Ozone 8
Focusrite Clarett 8Pre
Nord Stage 3
Nord Lead A1
DSI Mopho X4
Old 09-26-2011, 02:40 AM
RiF RiF is offline
Hardware inserts always come in pairs of an in- and output. Output 1 is probably assigned to your mix output, so you cannot use Input 1 for an insert. Did you try to use In-/Output 3 for inserting the compressor? This should work fine.
And an insert cable is not the right cable. You have to have two mono TRS cables. One goes out of you MBox's Output 3 into the input of your compressor and the other one goes out from the compressor's output back into Input 3 of your MBox.
And make sure that you enable Delay Compensation, because the trip out of your audio interface and back into it will cause some delay.
[IMG] code is Off
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
How to insert hardware as channel insert Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-19-2012 07:29 AM
connecting hardware insert to the 003+ / setting it up properly in protools le elmuerte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-06-2010 03:52 AM
Does hardware insert MUST be same I/O ? nedd Pro Tools TDM Systems (Mac) 8 03-22-2009 07:42 PM
Connecting external effects as insert to Mbox - help needed thepeaks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-12-2008 07:33 PM
