Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-28-2008, 09:07 AM
lwilliam lwilliam is offline
Default Importing downloaded songs into PT from iTunes
OK, I thought this would be simple, but apparently not....
Normally, I import a stereo wav file from a CD into my PT session when I'm mixing as an EQ and balance reference. This is pretty common and I've been doing this for years.
However, I thought I'd try downloading an appropriate tune from iTunes and import it into PT to accomplish the same thing without having to purchase a whole CD. No way, nada, can't do it.
This mp4 format is somehow protected. I tried converting it in iTunes to mp3, I tried using Audiofinder to convert it with the LAME mp3 converter, no way, nada, doesn't work - you get a file full of static.
What's a guy to do? How can I convert these files into something that I can import into PT or another editor? I also noticed that Peak LE would not load the mp4 file.
Interestingly, I can't use Walmart's mp3 download service either as it doesn't work with OS X, or I would simply switch to a company that provides importable downloads. (Amazon?)
If there's no way around this, then please point me to a legal download site that works with Macs, and gives me an importable file format.
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 01-28-2008, 11:09 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Importing downloaded songs into PT from iTunes
Burn it to an audio CD, then import audio straight off of the CD. Sucks that you have to "waste" a blank CD-r, but that's my work-around... Unless you route a signal from your computer into an input of Pro Tools.
-Ryan
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 01-28-2008, 01:44 PM
OK, I found some software that will remove the DRM encoding. It's supposedly legal. I'll give it a whirl and post back later if it works.
I think the iTunes store has seen their last purchase from me until they get rid of DRM. It's ridiculous that I can't play the "iTunes-purchased" song in something other than iTunes - or even convert it to mp3. Apparently, there are quite a few sites (Amazon, Rhapsody, Walmart, etc), that offer DRM-free downloads.
....it looks like Soundflower may also provide a way to get the song into PT. I'll try that as well.
Larry
Old 01-28-2008, 09:03 PM
The application, Fairgame, was based on Applescript and bombed on me. It uses a combination of QT and iMovie HD to accomplish the conversion.
However, Soundflower worked like a charm. Easy to use, just set the Default Audio output to be Soundflower (2 ch) in Audio/Midi setup, and loaded up Audacity, setting it's record input to Soundflower (2ch). It was realtime only, but then I had a wav file from which I can make an mp3 or whatever other format I want.
Larry
Old 01-30-2008, 06:35 PM
gwiz31 gwiz31 is offline
waste a cd-r? i use the same cd-rw strictly for that purpose. ill buy songs off itunes, burn it to the cd-rw, then import it as a regular aac or aiff file. then using disk utility, ill erase the cd-rw for next use. ill also erase the protected aac files on itunes. now all my songs are able to do whatever.
uploading songs into Pro Tools from downloaded songs in iTunes? GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-17-2009 09:52 PM
Importing reference songs from cd help... broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-22-2009 09:08 PM
Importing CD songs to PTs 6969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-21-2002 10:08 AM
Importing songs from CD BROWNIE Digidesign Hardware & Software 1 03-08-2002 11:45 PM
ITunes Loses songs! SteveU 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2001 04:56 PM
