  #21
Old 12-04-2000, 11:00 AM
mike connelly mike connelly is offline
Default Re: 24/96 Two Years away?
"almost every other playback device currently out there rolls off steeply frequecies above *sniff* @20k!! Bummer huh?"
I should hope so. If you don't, you'll have some pretty nasty aliasing.
"96k isn't marketing hype. I've A/B'ed the same recording at both 96k and 48k in laboratory conditions"
Without knowing the details, anectdotes like this are worthless. It's too easy to screw up an A/B test and cause differences - making "the same recording" at 96 and 48 isn't a trivial task.
Mike
  #22
Old 12-05-2000, 04:14 PM
Ang1970 Ang1970 is offline
I can understand Mike's skepticism of Greg's test (though I don't share his helpful and friendly demeanor :P ). There are a lot of possible variants which can turn the results inside out and sideways if they're not checked. Not the least of which is the number, type and quality of LPF's used to roll off over 48k. And about comparing 32 to 48, let's not even go there. Ok?
As masmit pointed out, changes in filtering schemes could drastically improve our piddly 48 thousand samples per second. Why go 96 when we haven't really experienced what 48 is capable of?
Reverbs? Yes, definitely, oversample and process fx at 96k or 128 or whatever floats your boat, then src back to 48. The files shouldn't need to be any bigger than they are already to get the same benefits of faster processing.
[This message has been edited by Ang1970 (edited December 05, 2000).]
Cheers,
Angelo Quaglia
WHY did I not do this 10 years ago?! midnightrambler Pro Tools TDM Systems (Mac) 6 08-19-2010 07:23 AM
What now , after all these years ...??? gweber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 05-31-2007 10:56 AM
5 Years JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-28-2005 06:05 PM
OT - How was your New Years gig? bigd General Discussion 7 01-05-2005 01:57 AM
OT - 60 Years After D-Day The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-07-2004 01:49 PM
