Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 10-09-2018, 01:41 AM
rolybarabas rolybarabas is offline
Default S3L-X / 4.5.3.3 hw inserts not working
Hello everybody!
Although until 2 weeks ago they worked fine, my hardware inserts do not work anymore. I do not know why, as long as all my configuration, show file / snapshot is the same.
I tried to bypass with an XLR cable and still not working. Engine Analog OUT 1 to Engine Analog IN 1.
I tried to check the allocated E3 inserts and use them as inputs and outputs and they work. It seems that there is no hardware problem.
Config: 3 Tascam TA-1VP linked on E3 engine, analog ch 1,2,3 (vocals).
Venue 4.5.3.3
Somebody can help me?
Many thanks!
Old 10-09-2018, 03:35 PM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: S3L-X / 4.5.3.3 hw inserts not working
Does audio pass correctly if you bypass the HW insert on those channels?
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
Old 10-10-2018, 12:46 AM
Yes, Ryan. If I swtich off the hw insert, everything is working normally.
- I tried to pick up signal from Engine Analog OUT 1 (insert is Engine Analog 1), of course while hw insert is on - no signal.
- I tried to send signal to Engine Analog IN 1 (insert is Engine Analog 1), of course while hw insert is on - no signal.
Could it be a hardware failure?
Thank U very much for your attention!
Old 10-13-2018, 06:17 AM
Hi Ryan
We re-check the Engine hardware analog inputs / outputs and all the 4 outputs do not work.
That means:
- All 4 analog inputs work
- All 4 analog outputs do not work
- All AES / EBU inputs / outputs work
I suspect the D/A converters of E3.
Do U think it's worth to do a system restore (re-install Venue 4.5.3.3)?
Best regards!
Old 10-14-2018, 08:36 AM
Valentyn Valentyn is offline
Originally Posted by rolybarabas View Post
Hi Ryan
That means:
Best regards!
I think you have a hardware failure (ribbon cable?) and you better call support.
Old 10-14-2018, 02:04 PM
Karel Noon Karel Noon is offline
What about a reset of the I/O, have you tried that?
Old 10-14-2018, 11:39 PM
Hi Valentyn, that's what I also think, thanks for your opinion, I will try to send the engine to an authorized repair center. Do you think it's worth to do a re-install of Venue system?
Hi again, Valentyn! Could you recommand me one ore more authorized repair center(s)? Maybe the best ones. All over Europe, not necessarily close.
Old 10-14-2018, 11:45 PM
Hi Karel, I will try to do a I/O reset.Do you think it's worth to lose one day and to do a re-install of Venue system? My opinion is no, but I will keep in mind your view.
Best regards!
Old 10-15-2018, 02:27 PM
If the reset Engine I/O Option fails a clean install might be a good try, it’s not a whole day, and definitely less downtime than bringing the engine to a repair shop.
Old 10-16-2018, 01:55 AM
I don't think reinstall will help. You should call VENUE Support and they will guide you.
Mbox 3 Pro inserts not working fallenidols macOS 6 12-20-2011 03:38 AM
Aux inserts not working on 8.0.4, but work on 8.0 and previous futreboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-14-2010 04:20 PM
Hardware Inserts not working goom Pro Tools TDM Systems (Mac) 5 09-02-2006 05:23 PM
Inserts in PTLE 6.7 not working richmix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2005 04:52 PM
Saving amplitube inserts not working Guitarman002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-19-2004 09:12 PM
