Old 10-19-2015, 12:20 PM
Edwoods Edwoods is offline
Default Rig volume
Quick question, Which output in the back of the 11r should I use to be able to use the Rig volume knob on the front of the unit? Thanks to all!
Old 10-19-2015, 12:30 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Rig volume
What do you mean by "Rig Volume Knob"? Because the knob on the front is a Volume knob and you can choose exactly what it effects in the Edit Menu.
Hold EDIT/BACK
Go to page 3 and select VOLUME CONTROL.
From there you can choose Main Outputs, the Amp outputs, or ALL.
There is a Rig Volume, but that effects the rig (the whole chain of amps, effects, cab) and is not a physical knob on the interface.
Old 10-19-2015, 01:21 PM
guitarded's Avatar
guitarded guitarded is offline
New here so... hope this is what you are asking... but you can assign it whatever you need
It is in the user options.
hold the edit/back button
scroll to volume control
In this screen, use the lit control knob to choose
which output volume is controlled by the Volume
knob on the front panel of Eleven Rack.
The choices are as follows:
• Main Outputs (default setting)
• Output to Amp 1
• Output to Amp 2
• Outputs to Amp 1 & 2
• Main + Outputs to Amp 1 & 2
As a dog returns to his vomit, so a fool repeats his folly
Fender HW1 Strat. 11-R, Quilter 101, TC-G Major, Zoom G5n, Zoom G3, Fender Mustang Floor, Behringer FCB1010,
Old 10-19-2015, 01:24 PM
guitarded's Avatar
Too late
Old 10-19-2015, 03:41 PM
zedhed's Avatar
zedhed zedhed is offline
Ya gotta be quick on the draw to beat the 'B' man.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 10-19-2015, 04:40 PM
Benoni's Avatar
Not sure if that's a good thing or I should get a life already.....
Old 10-19-2015, 06:35 PM
guitarded's Avatar
Ha Ha!!!
Monitoring volume in Pro Tools doesn't match computer volume Drakken Pro Tools M-Powered (Win) 0 01-17-2012 02:56 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
cannot be as an audio record volume because it is formatted as a FAT volume rtm Pro Tools TDM Systems (Win) 3 12-18-2008 09:52 AM
Can I Group a Channel Volume with an Aux Send Volume? acacia Pro Tools TDM Systems (Mac) 10 08-10-2007 12:26 PM
Special paste midi volume to audio volume? Richard Fairbanks Pro Tools TDM Systems (Mac) 0 07-30-2003 09:52 AM
