DBX Noise Reduction Plug-in
Never say I didn't give ya'll something.
I just had to decode some of my old tapes from 1982-83. The were DBX Type 1 and we had just sold our two channel unit last year. I came up with this for the Dyn 3.0 Expander/Gate and it works pretty darn well....the setting are based on 18dbfs=0dbvu. Enjoy DBX De-Code.tfx I just realized I can't attach anything here. If you would like this eamil me [email protected] We all need to help each other. |
Re: DBX Noise Reduction Plug-in
I think the old DBX NR box was a straight 2/1 compression ratio with a pre emphasis curve.
Pirata Capo is quite right. if you REALLY want to do the DBX thing, you need the preemphasis curve that it uses to get the compansion right.
there is a simple bandpass filter ahead of the entire DBX record/play back process which has a 3db roll off at 27Hz and 27kHz. essentially it is a flat +5dB between 100Hz and 1kHz. At 1kHz there is a rise to +10dB at 7kHz -- don't know how wide the Q is. Above 7kHz, there is a bell that descends from +10dB(7Hz)to 0dB at 20kHz. Below 100 Hz it rolls off to -3dB at 20Hz. DBX 150 TYPE I AND MANUAL
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
You sir, are absolutely right. However, the problem with the emphasis curve is that it is constantly changing based on the input. What happens is that the input is fed into a separate amplifier chip this is then used to control a VCA chip which constantly shifts the threshold of the EQ curve. I found it less distracting to do a simple lo-pass filter at 12db/octive. This is just a starting point for getting us with no DBX hardware available to do a quick de-code.
Thanks for your input! |
would you consider posting the preset here:
http://www.digitalaudiorock.com/ it would let anyone download it with out heeding to e-mail you
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I realize that this thread is more than 6 years old, however, if anyone is still interested in decoding dbx noise reduction using standard Pro Tools plugins, I have developed a method based on the original pre-empasis curves published by dbx.
Most of the information above is essentially correct, but incomplete. dbx noise reduction decoding requires a pre-emphasis EQ curve in the control (trigger) path of the 1:2 expander, as well as a de-emphasis EQ curve in the audio path after the expander. Visit this webpage that I have posted to get all the details in my article: A Method For Decoding dbx Noise Reduction Using Standard Plugins
Bob W. iMac 24" 2.16 Mhz Intel Core 2 Duo 3GB RAM OSX 10.7.5 MacBook Pro 13" 2.26 Mhz Intel Core 2 Duo 2GB RAM OSX 10.7.5 Pro Tools HD9 003 Rack+ ProControl + Fader Pack Euphonix MC Mix, MC Control |
Noise reduction plug in | Peter Groom | Pro Tools TDM Systems (Mac) | 19 | 02-06-2010 10:14 PM |
anyone know of a free noise reduction plug in | billymc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-26-2006 09:40 AM |
DNR noise reduction plug in | digitum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-04-2004 12:41 PM |
Room noise reduction plug-ins? | Brickdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2003 04:58 PM |
Noise Reduction Plug In | schnauser | Tips & Tricks | 7 | 11-16-2002 03:43 PM |
