whats the difference
whats the difference recording with 16 bit and 24 bit could someone be real simple for me i'm new to recording? thank you.
Re: whats the difference
Real simple? 24 bit is higher resolution, therefore better sound quality than 16 bit. Recording, editing and processing should be done at 24 bit. However CD wave files are 16 bit, so you have to then bounce your 24 bit files down to 16 in order to play them on a CD player.
When you get a better feel for all this, do a search on "dither", which is a process you should include when you bounce from 24 to 16 bit files.
Soundsurfr MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM M-Audio Firewire 1814 Yosemite OS |
If you're aquainted with analog tape based recording, bit depth is kind of like tape width, the wider the tape, the beter the fidelity. Sample rate is kind of like tape speed, the faster the speed the better the fidelity.
And to further the analogy - the greater the bit depth and the higher the sample rate - the more media you consume while recording.
"If you're aquainted with analog tape based recording, bit depth is kind of like tape width, the wider the tape, the beter the fidelity. Sample rate is kind of like tape speed, the faster the speed the better the fidelity."
- but the second mouse gets the cheese |
Whats the difference between LE & M-Powered PT? | Robbie2327 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-30-2008 05:56 AM |
Whats the difference between v4.3 VS v5.0 session? | grivel | Post - Surround - Video | 0 | 05-09-2004 07:19 PM |
OT - whats the difference between the Beta 57/57a? | shutupandshave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-28-2004 01:30 PM |
vst & vsti, whats the difference? | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-21-2004 07:46 AM |
Whats the difference between AUX & BUS | east3rdst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-09-2001 05:41 AM |
