Old 04-04-2002, 09:29 AM
Euan Euan is offline
Default Fader Problems
Fader 8 on my expansion pack is not tracking at all and when I re boot the PC it just slams to the top and then back to the bottom quite hard. In recal mode it will some time respond fine and other times just slam to the top and bottom. Any body else have this problem? If so what is the fix.
Thanks
Euan
VO2 Mix Inc.
Euan Hunter
VO2 Mix Inc.
ehunter@vo2mix.ca
Old 04-04-2002, 10:32 AM
Stan Cotey Stan Cotey is offline
Default Re: Fader Problems
It sounds to me like you might have a faulty fader. Digidesign offers a refurbishment program for faders that costs $50US each, or you may purchase a new spare for roughly $175US. You would probably use the new fader as a spare while your original was being refurbished. Your ProControl or Fader Pack will run quite happily with a fader missing if you want to keep the cost to a minimum. If you would like more information about this, please contact customer support. In the US, the number is (650) 731-6100. You'll need to work your way through a sometimes frustrating series of menu choices to get to a real live human being.
Good luck and write back if you are still experiencing problems.
Stan Cotey
Product Manager, Control Surfaces
Old 04-04-2002, 11:53 AM
DigiTechSupt's Avatar
Hi All
Actually the phone tree here at Digidesign Customer service has been updated and is much easier and faster to use. A real "Live" human being is only a few options away. Please give us a call and we can get you set up.
Thanks.
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 04-04-2002, 03:13 PM
nozza1 nozza1 is offline
Currently have exactly the same problem with fader 1 on my fader pack. Fortunately my unit is in warranty so I can exchange my faderpack or get a warranty repair. Good luck.
Old 04-05-2002, 01:12 PM
Don Geppert Don Geppert is offline
We recently had a "touch sensitivity" problem with one fader. It was returned to Digi for repair and we also bought 2 spare faders which was done so none of the other faders on our 2 ProControls will ever go bad .... you all know how it works!
The repair turnaround on the damaged fader was very fast to Canada and due to an original soldering fault, this out of warrantee item was refurbished at no charge.
Good work on Digi's side of the fence, and Stan was very helpful in all of this.
[img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img]
Music Industry Arts
Fanshawe College
MIA2@sympatico.ca
D-Command ES + Fader Madule Fader Problems FedericoF ICON & C|24 11 05-24-2013 04:27 PM
C-8 problems - touching fader 1 writes fader 2, etc MixerGuy ProControl, Control|24, Command|8 27 08-16-2007 09:23 AM
Fader problems steals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-30-2004 07:24 PM
fader problems on the 002 theaudiolounge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2004 12:13 PM
002 Fader Problems sekorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-06-2003 10:51 PM
