Old 12-13-2014, 06:12 PM
Barry Johns Barry Johns is offline
Default ProControl Fader Randomky Looses Connection 2 PT
One of the faders on my main PC unit occasionally looses its connection to protools. All other buttons/controls on that channel works. No have to turn the PC off and then back on again to get the fader to move the DAW FADER in PT.
Any suggestions?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-16-2014, 03:23 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Re: ProControl Fader Randomky Looses Connection 2 PT
Hi Barry,
I would advice to open the unit, disconnect the ribbon cable between the fader and the IC-board, clean contacts and reconnect it.
Another tip is to disconnect all 8 faders, remove the ribbon cables and reconnect the cables, but make sure you don't use the same cable for the same fader (use the cable from fader 1 for fader 2, the cable from fader 2 for fader 3, etc.). In this way each fader gets a 'new' cable with 'new' contacts (meaning all pins and busses connect in a new way, lowering the risk for bad contacts)
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
System 1: Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.13.6 - Magma EB7 - PT HDX3 - PT Ultimate 2018.12 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x3)
System 2: Mac Pro (Mid 2010) 3.33 GHz 6-core - 32 GB RAM - OS X 10.9.5 - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192D I/O - SYNC I/O
Old 12-25-2014, 12:31 PM
blackmacdaddy blackmacdaddy is offline
Originally Posted by Barry Johns View Post
Any suggestions?
DMB's suggestions are great.
But, you could also just hit utility button > Test > Faders > Recal (press 1 - 3 times, YMMV)
Esc and you're out. No need to power cycle and more graceful. If it happens in front of a client just say: "Hey, a sleepy fader" and 10 seconds later it is back online.
Hope it helps, all the Best
Walt
It's only R'n'R but I like it.
Core Audio Manager looses connection to interface rainerpuschner General Discussion 1 05-27-2014 01:04 AM
DIGIRACK 002 looses connection to MOTU 8pre via ADAT conn. sekie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-12-2007 07:37 AM
002 looses connection... dcdownunder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-19-2006 01:01 AM
digi002r looses firewire connection during session richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-23-2004 07:51 PM
Computer looses internet connection after quitting PT6 dkrz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-07-2003 09:39 AM
