Old 03-29-2005, 12:50 PM
neomodo neomodo is offline
Default Repost - Unable to \"print\" to another track !!@!!
Originally I thought it might me a problem with my plugin Amplitube - I couldn't get another track to record the effected signal. Then I tried Guitar Rig - no difference - and I have been trying with Reason in an AUX channel to no avail.
I want to be able to record a new track from an existing one =- pretty standard stuff right? So for example - I have Reason in an Aux track and I want to dump the piano into a PT track rather than keep using reason. I have a guitar track with a plugin (Amplitube / GUitar Rig -take your pick) and I want to record it to a track with the effects so I can shut off the plugin.
1. I have tried to send the OUTPUT from either an AUX or AUDIO channel to BUS 1&2 or 3&4
2. In the new track I designate the input as the corresponding BUS 1&2 or 3&4 -
3. The OUTPUT of the new channel/track-to-be is pointing to the regular outputs INTERFACE ANALOG 1&2
4. The new track is record enabled -
I see no activity and hear nothing -
I have deleted and recreated my BUS config using the DEFAULT SETTINGS - NADA
What am I missing? What am I doing wrong? I have searched for this topic but either my queries were idiotic or my terminology is incorrect...
thanks for the help!
Old 03-29-2005, 01:20 PM
rockrev rockrev is offline
Default Re: Repost - Unable to \"print\" to another track !!@!!
I once had a problem routing tracks in 6.1.1 - most of the time, no problem. But every once and a while it would bug out - sometimes no sound at all after routing.
What version are you using and what's your basic system?
rockrev
End world poverty: ONE
Old 03-29-2005, 02:23 PM
Ducky Ducky is offline
Although rare, I too have had PTLE v6.4 simply ignore a routing. Rebooting PT fixes it every time.
How to print each MIDI track to Audio? PT9 sylviesongs macOS 2 10-19-2011 03:07 PM
Could someone print a piano track for me? Studio Dweller Pro Tools TDM Systems (Mac) 4 11-01-2006 06:48 PM
how to print a midi track? shret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-27-2006 05:51 AM
How To "Print" Track? tikboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-30-2006 11:17 PM
How do I print an Amplitube track? meatsurfn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-24-2005 10:28 PM
